sequences
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
1 - Undefined
2 - Zone
3 - Ply
datalines
The number of layers for config 2.
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
integrationpoints
The list of integration points for each of the ply IDs for config 2.
Type: integer array
internalid
materials
The list of materials for each of the ply IDs for config 2.
Type: entity array
name
The name of the entity.
Type: string
orientations
The list of orientations for each of the ply IDs for config 2.
Type: double array
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
plyids
The list of ply IDs for config 2.
Type: entity array
resultrequests
The list of result request options for each of the ply IDs for config 2.
Type: integer array
shape
The list of elements which define the shape of the zone for config 2.
Type: entity array
solverkeyword
The name of the solver keyword.
Type: string
thicknesses
The list of thicknesses for each of the ply IDs for config 2.
Type: double array
Version History
2020.1
