alesmoothings
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
101 - LS-DYNA *ALE_SMOOTHING
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
firstmasternodeid
The ID of the first ALE smoothing master node.
Type: entity
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
ipre
Option to apply smoothing constraints before or after mesh relaxation.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
secondmasternodeid
The ID of the second ALE smoothing master node.
Type: entity
slavenodeid
The ID of the ALE smoothing slave node.
Type: entity
solverkeyword
The name of the solver keyword.
Type: string
xco
The x-coordinate of the constraint vector.
Type: double
yco
The y-coordinate of the constraint vector.
Type: double
zco
The z-coordinate of the constraint vector.
Type: double
Version History
2019
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
