cards
Unless otherwise specified, data names are accessible in level 3 only.
Most of the information for a card is contained in the attributes owned by the card.
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
cardimage
The name of the assigned card image.
Type: string
cardimagetype
The type of the assigned card image.
Type: string
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
name
The name of the entity.
Type: string
solverkeyword
The name of the solver keyword.
Type: string
status
The status of the entity.
Type: integer
Version History
2020.1 - Added new data name solverkeyword.
