modules
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
children
Recursive list of children module IDs. Valid for hm_getvalue query only. Type: integer array
childrenids
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
1 - Prototype
2 - Occurrence
conflictidlist
The list of conflict IDs as internal IDs, with reserve range. If row=<entity_type> is specified, this will be for the specific entity type in the module. If column=<idpool_number> is specified, row=<entity_type> must also be specified, and this will be for the specific entity type and ID pool. Valid for hm_getvalue query only. Type: integer array
conflictwithreservedids
The list of conflict IDs with reserve range. If row=<entity_type> is specified, this will be for the specific entity type in the module. If column=<idpool_number> is specified, row=<entity_type> must also be specified, and this will be for the specific entity type and ID pool. Valid for hm_getvalue query only. Type: string
correctoptions
List of ID manager correction options. Valid for hm_getvalue query only. Type: string
creator_tag
The tag that defines the creator/use case of the module. Valid for hm_getvalue query only. Type: string
currentcorrectoption
The current ID manager correction option. Type: string
currentnewidoption
The current ID manager new ID option. Type: string
currentstatus
The current ID manager status. Valid for hm_getvalue query only. Type: string
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
entitytypes
List of entity types existing in the module. Valid for hm_getvalue query only. Type: string array
excludeshowhidestate
The show (true)/hide (false) state of excluded entity types in the ID manager. Valid for hm_getvalue query only. Type: Boolean
exclusive
The type of exclusive ID ranges. Valid for hm_getvalue query only. Type: integer
hasconflicts
True or false if there are any conflict IDs. Valid for hm_getvalue query only.
hashidestate
True or false if there is a hide state on the submodel or excluded entities. Valid for hm_getvalue query only.
haslocked
True or false if there are any locked IDs. Valid for hm_getvalue query only.
hasoffset
True or false if there are any offset IDs. Valid for hm_getvalue query only.
hasoverflows
True or false if there are any overflow IDs. Valid for hm_getvalue query only.
hasreserved
True or false if there are any reserved IDs. Valid for hm_getvalue query only.
HW_CID
List of component IDs owned by the module. Type: unsigned integer
HW_CID_OFFSET
The component ID offset assigned to a sibling part instance. Type: unsigned integer
HW_Material
List of material names assigned to components or properties of the module. Type: string
HW_MID
List of material IDs assigned to components or properties of the module. Type: unsigned integer
HW_PID
List of property IDs assigned to components of the module. Type: unsigned integer
HW_Thickness
List of property thicknesses assigned to components of the module. Type: double
id
The ID of the entity.
idlist
The list of internal IDs. If row=<entity_type> is specified, this will return only the specific entity type in the model. If column=<idpool_number> is specified, row=<entity_type> must also be specified, and this will return the specific entity type and ID pool. Valid for hm_getvalue query only.
idmanagerstatus
The ID manager status. Valid for hm_getvalue query only. Type: string array
idsoverflowoptions
List of ID manager overflow options. Valid for hm_getvalue query only. Type: string array
include
The ID of the include file the entity is organized in.
Type: entity
includeid
instance_id
The ID of the instance of the module.
Type: integer
internalid
is_positioned
0 - Has a default position.
1 - Has a non-default position
Type: Boolean
is_root
0 - Is not the root of the hierarchy
1 - Is the root of the hierarchy
Type: Boolean
library_revision
If the prototype is stored in the Part Library, this is the library revision, prototype UDM ID, major revision and study revision. Valid for hm_getvalue query only. Type: string
library_udm_id
If prototype UDM ID stored in the current Part Library. Valid for hm_getvalue query only. Type: string
lockedids
The list of locked IDs. row=<entity_type> must be specified. If column=<idpool_number> is specified, this will be for the specific entity type and ID pool. Valid for hm_getvalue query only. Type: integer array
lockfeids
To set locked entity solver IDs when importing from CSV.
major_revision
The prototype major revision as PDM metadata. Type: string
max
The max of the ID range. If row=<entity_type> is specified, this will be for the specific entity type in the module. Valid for hm_getvalue query only. Type: integer
maxid
The maximum ID occupied. If row=<entity_type> is specified, this will be for the specific entity type in the module. If column=<idpool_number> is specified, row=<entity_type> must also be specified, and this will be for the specific entity type and ID pool. Valid for hm_getvalue query only. Type: integer
min
The min of the ID range. If row=<entity_type> is specified, this will be for the specific entity type in the module. Valid for hm_getvalue query only. Type: integer
minid
The minimum ID occupied. If row=<entity_type> is specified, this will be for the specific entity type in the module. If column=<idpool_number> is specified, row=<entity_type> must also be specified, and this will be for the specific entity type and ID pool. Valid for hm_getvalue query only. Type: integer
module_triple_dxyz1, module_triple_dxyz2, module_triple_dxyz3, module_triple_xyz0
These are all triples, corresponding to the 4 rows of the transformation matrix for the module. Valid for hm_getvalue query only. Type: triple double
name
The name of the entity.
Type: string
newidoptions
List of ID manager new ID options. Valid for hm_getvalue query only. Type: string array
numberofchildren
The number of recursive children of the module. Valid for hm_getvalue query only. Type: integer
numberofconflicts
The number of conflict IDs. If row=<entity_type> is specified, this will be for the specific entity type in the module. If column=<idpool_number> is specified, row=<entity_type> must also be specified, and this will be for the specific entity type and ID pool. Valid for hm_getvalue query only. Type: integer
numberofentities
The number of entities in the module. If row=<entity_type> is specified, this will be for the specific entity type in the module. If column=<idpool_number> is specified, row=<entity_type> must also be specified, and this will be for the specific entity type and ID pool. Valid for hm_getvalue query only. Type: integer
numberoflockedids
The number of locked IDs for an entity type in an module. row=<entity_type> must be specified. If column=<idpool_number> is specified, this will be for the specific entity type and ID pool. Valid for hm_getvalue query only. Type: integer
numberofoverflow
The number of overflow IDs. If row=<entity_type> is specified, this will be for the specific entity type in the module. If column=<idpool_number> is specified, row=<entity_type> must also be specified, and this will be for the specific entity type and ID pool. Valid for hm_getvalue query only. Type: integer
numberofreservedids
The number of reserved IDs. row=<entity_type> must be specified. If column=<idpool_number> is specified, this will be for the specific entity type and ID pool. Valid for hm_getvalue query only. Type: integer
offset
The offset. row=<entity_type> must be specified. If column=<idpool_number> is specified, this will be for the specific entity type and ID pool. Valid for hm_getvalue query only. Type: integer
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
overflowids
The list of overflow IDs (integer array). If row=<entity_type> is specified, this will be for the specific entity type in the module. If column=<idpool_number> is specified, row=<entity_type> must also be specified, and this will be for the specific entity type and ID pool. Valid for hm_getvalue query only. Type: integer array
parent
The parent of the module. Valid for hm_getvalue query only. Type: integer
parentid
PDM_ID
List of IDs as PDM metadata. Type: integer
PDM_Material
List of material names as PDM metadata. Type: string
PDM_MeshFlag
List of mesh flags as PDM metadata. Type: string
PDM_MID
List of material IDs as PDM metadata. Type: integer
PDM_PartNumber
List of part numbers as PDM metadata. Type: string
PDM_PID
List of property IDs as PDM metadata. Type: integer
Generally formatted as a list of 4 values: <Property ID>, ?<Instance Increment>?, ?<Component Increment>?, ?<Component Offset>?
PDM_Revision
List of revisions as PDM metadata. Type: integer
PDM_Thickness
List of property thicknesses as PDM metadata. Type: double
prototype_id
The ID of the prototype module if the specified module is an occurrence
If a prototype, this is just its own ID.Valid for hm_getvalue query only. Type: integer
prototype_instance_count
The number of instances created for the prototype. If an occurrence, returns 0. Type: integer
range_offset
The ID range offset. Type: integer
releaseidsconflictwithreserves
Release the list of reserved IDs. row=<entity_type> must be specified. If column=<idpool_number> is specified, this will be for the specific entity type and ID pool. Type: integer array
releasereservedids
The list of release reserved IDs. row=<entity_type> must be specified. If column=<idpool_number> is specified, this will be for the specific entity type and ID pool. Valid for hm_getvalue query only. Type: integer array
rep_filename
The full path and file name of an occurrence. Returns empty for prototypes and occurrences without a file. Type: string
rep_name
The name of the representation as shown in the Part Browser "Representation" column. Valid for hm_getvalue only. Type: string
rep_type
The type of occurrence. Returns N/A for prototypes and occurrences without a type. Type: string
reservedids
The list of reserved IDs. row=<entity_type> must be specified. If column=<idpool_number> is specified, this will be for the specific entity type and ID pool. Valid for hm_getvalue query only. Type: integer array
reserveidoption
The ID manager reserve ID option. Type: string
reserverange
Type: integer
reserverangemax
The max of the reserve range. row=<entity_type> should be specified, this will be for the specific entity type in the module. Type: integer
reserverangemin
The min of the reserve range. row=<entity_type> should be specified, this will be for the specific entity type in the module. Type: integer
showhidestate
The show/hide state on the submodel or excluded entities.
solverkeyword
The name of the solver keyword.
Type: string
structural_type
The structural type of the module (part or assembly). Type: string
study_revision
The prototype study revision as PDM metadata. Type: string
supportedtypesandpools
The list of types and pool numbers which are supported by ID Manager. The return format is {-1 1 -2 3 …} where a negative number is the entity type while a positive number is the ID pool number. Valid for hm_getvalue query only.
Type: integer array
transformation_id
The ID of the transformation entity.
Type: entity
transformation_matrix
The transformation matrix of the entity.
Only valid for occurrences, returns empty for prototypes. Type: string
typesandpools
The list of types and pool numbers which are listed in the ID Manager. The return format is {-1 1 -2 3 …} where a negative number is the entity type while a positive number is the ID pool number. Valid for hm_getvalue query only.
Type: integer array
typesandpoolswithreservedids
The list of types and pool numbers which have reserved IDs. The return format is {-1 1 -2 3 …} where a negative number is the entity type while a positive number is the ID pool number. Valid for hm_getvalue query only.
Type: integer array
typesofexclusiveidranges
The types of exclusive ID ranges. Valid for hm_getvalue query only. Type: integer array
typesofindividualidranges
The types of individual ID ranges. VValid for hm_getvalue query only. Type: integer array
typeswithreservedids
The list of reserved ID entity types. If row=<entity_type> is specified, this will be for the specific entity type in the module. If column=<idpool_number> is specified, row=<entity_type> must also be specified, and this will be for the specific entity type and ID pool. Valid for hm_getvalue query only.
Type: integer array
udm_id
The ID of the entity in UDM. Type: string
unique_id
The unique ID of the entity. Type: string
unsettypesandpools
The list of types and pool numbers which do not have an ID range defined. The return format is {-1 1 -2 3 …} where a negative number is the entity type while a positive number is the ID pool number. Valid for hm_getvalue query only.
Type: integer array
variant_condition
If non-empty, implies that the part is used as a variant in one or multiple part configurations. Type: string
variant_scope
Along with variant_condition, this is used to describe which part configurations the part belongs to as a variant. Type: string
Version History
2017.1 - Added new data name rep_name.
2017.2 - Added new data names variant_condition and variant_scope.
2019 - Added new data names idlist, is_positioned, structural_type, supportedtypesandpools, typesandpools, typesandpoolswithreservedids and unsettypesandpools.
2020 - Added new data names color_rgb, HW_CID_OFFSET, instance_id and transformation_id.
2020.1 - Added new data names excludeshowhidestate and solverkeyword.
