outputrequests
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
disp
True if DISP is an active output-based eigenvector. Valid for hm_getvalue query only.
Type: Boolean
disp_option
1 – ALL
2 – YES
3 – NONE
4 – NO
5 – SID
Type: string
disp_sid
The grid set ID.
Type: string
eke
True if EKE is an active output-based eigenvector. Valid for hm_getvalue query only.
Type: Boolean
eke_group
1 – PROP
2 – COMP
3 – SET
Type: string
eke_option
1 – ALL
2 – YES
3 – NONE
4 – NO
5 – SID
Type: string
eke_sid
The element set ID.
Type: string
ese
True if ESE is an active output-based eigenvector. Valid for hm_getvalue query only.
Type: Boolean
ese_group
1 – PROP
2 – COMP
3 – SET
Type: string
ese_option
1 – ALL
2 – YES
3 – NONE
4 – NO
5 – SID
Type: string
ese_sid
The element set ID.
Type: string
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
Version History
2020
2020.1 - Added new data name solverkeyword.
