aletanktests
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
amgida
The ALE multi-material group ID (AMMGID) of the air.
Type: entity
amgidg
The ALE multi-material group ID (AMMGID) of the gas.
Type: entity
aorif
The total inflator orifice area.
Type: double
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
101 - LS-DYNA *ALE_TANK_TEST
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
machl
The limiting MACH number for the gas at the throat.
Type: double
mdotlc
LCID for mass flow rate as a function of time.
Type: entity
name
The name of the entity.
Type: string
numpnt
The number of points.
Type: integer
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
pamb
The tank pressure before jetting.
Type: double
pfinal
The final equilibriated tank pressure after the tank test.
Type: double
solverkeyword
The name of the solver keyword.
Type: string
tankv
The tank volume.
Type: double
velmax
The maximum allowable gas velocity across the inflator orifice.
Type: double
Version History
2019
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
