subsystemconfigurations
Unless otherwise specified, data names are accessible in level 3 only.
activestate
True if the configuration is active, false otherwise.
Type: Boolean
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
functionalType
The functional type. Valid for hm_getvalue query only.
1 - Analysis
2 - Standard
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
The member subsystem configurations.
Type: entity array
subsystems
The member subsystems.
Type: entity array
subsystemsets
The member subsystem sets.
Type: entity array
Version History
2020
2020.1 - Added new data name solverkeyword.
