includefiles
All data names are accessible only via Tcl and not via the template system.
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
children
Recursive list of children include IDs. Valid for hm_getvalue query only.
Type: integer array
childrenids
Type: integer array
conflictidlist
The list of conflict IDs as internal IDs, with reserve range. If row=<entity_type> is specified, this will be for the specific entity type in the include. If column=<idpool_number> is specified, row=<entity_type> must also be specified, and this will be for the specific entity type and ID pool. Valid for hm_getvalue query only.
Type: integer array
conflictwithreservedids
The list of conflict IDs with reserve range. If row=<entity_type> is specified, this will be for the specific entity type in the include. If column=<idpool_number> is specified, row=<entity_type> must also be specified, and this will be for the specific entity type and ID pool. Valid for hm_getvalue query only.
Type: integer array
correctoptions
List of ID manager correction options. Valid for hm_getvalue query only.
Type: string
currentcorrectoption
The current ID manager correction option.
Type: string
currentnewidoption
The current ID manager new ID option.
Type: string
currentstatus
The current ID manager status. Valid for hm_getvalue query only.
Type: string
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
dirty_flag_for_export
Is true when:
- An include or any entity inside the include is modified
- Whenever a cross-referenced material or property is modified
This is reset to false if the include is exported. Valid for hm_getvalue query only.
Type: Boolean
displayed_status
The display status. Valid for hm_getvalue query only.
Type: Boolean
entitytypes
List of entity types existing in the include. Valid for hm_getvalue query only.
Type: string array
exclusive
The type of exclusive ID ranges. Valid for hm_getvalue query only.
Type: integer
flag1
Solver flag 1. Valid for hm_getvalue query only.
Type: string
flag2
Solver flag 2. Valid for hm_getvalue query only.
Type: string
fullname
The full name/path of the include. The path may be absolute or relative depending on how it is defined. Valid for hm_getvalue query only.
Type: string
hasconflicts
True or false if there are any conflict IDs. Valid for hm_getvalue query only.
hashidestate
True or false if there is a hide state on the submodel or excluded entities. Valid for hm_getvalue query only.
haslocked
True or false if there are any locked IDs. Valid for hm_getvalue query only.
hasoffset
True or false if there are any offset IDs. Valid for hm_getvalue query only.
hasoverflows
True or false if there are any overflow IDs. Valid for hm_getvalue query only.
hasreserved
True or false if there are any reserved IDs. Valid for hm_getvalue query only.
id
The ID of the entity.
idlist
The list of internal IDs. If row=<entity_type> is specified, this will return only the specific entity type in the model. If column=<idpool_number> is specified, row=<entity_type> must also be specified, and this will return the specific entity type and ID pool. Valid for hm_getvalue query only.
idmanagerstatus
The ID manager status. Valid for hm_getvalue query only.
Type: string array
idsoverflowoptions
List of ID manager overflow options. Valid for hm_getvalue query only.
Type: string array
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
lockedidlist
The list of locked IDs as internal IDs. row=<entity_type> must be specified. If column=<idpool_number> is specified, this will be for the specific entity type and ID pool. Valid for hm_getvalue query only.
Type: integer array
lockeids
The list of locked IDs. row=<entity_type> must be specified. If column=<idpool_number> is specified, this will be for the specific entity type and ID pool. Valid for hm_getvalue query only.
Type: integer array
lockfeids
To set locked entity solver IDs when importing from CSV.
max
The max of the ID range. If row=<entity_type> is specified, this will be for the specific entity type in the include. Valid for hm_getvalue query only.
Type: integer
maxid
The maximum ID occupied. If row=<entity_type> is specified, this will be for the specific entity type in the include. If column=<idpool_number> is specified, row=<entity_type> must also be specified, and this will be for the specific entity type and ID pool. Valid for hm_getvalue query only.
Type: integer
min
The min of the ID range. If row=<entity_type> is specified, this will be for the specific entity type in the include. Valid for hm_getvalue query only.
Type: integer
minid
The minimum ID occupied. If row=<entity_type> is specified, this will be for the specific entity type in the include. If column=<idpool_number> is specified, row=<entity_type> must also be specified, and this will be for the specific entity type and ID pool. Valid for hm_getvalue query only.
Type: integer
newidoptions
List of ID manager new ID options. Valid for hm_getvalue query only.
Type: String Array
numberofchildren
The number of recursive children of the include. Valid for hm_getvalue query only.
Type: integer
numberofconflicts
The number of conflict IDs. If row=<entity_type> is specified, this will be for the specific entity type in the include. If column=<idpool_number> is specified, row=<entity_type> must also be specified, and this will be for the specific entity type and ID pool. Valid for hm_getvalue query only.
numberofentities
The number of entities in the include. If row=<entity_type> is specified, this will be for the specific entity type in the include. If column=<idpool_number> is specified, row=<entity_type> must also be specified, and this will be for the specific entity type and ID pool. Valid for hm_getvalue query only.
Type: integer
numberoflockedids
The number of locked IDs for an entity type in an include. row=<entity_type> must be specified. If column=<idpool_number> is specified, this will be for the specific entity type and ID pool. Valid for hm_getvalue query only.
Type: integer
numberofoverflow
The number of overflow IDs. If row=<entity_type> is specified, this will be for the specific entity type in the include. If column=<idpool_number> is specified, row=<entity_type> must also be specified, and this will be for the specific entity type and ID pool. Valid for hm_getvalue query only.
Type: integer
numberofreservedids
The number of reserved IDs (integer). row=<entity_type> must be specified. If column=<idpool_number> is specified, this will be for the specific entity type and ID pool. Valid for hm_getvalue query only.
Type: integer
offset
The offset. row=<entity_type> must be specified. If column=<idpool_number> is specified, this will be for the specific entity type and ID pool. Valid for hm_getvalue query only.
Type: integer
overflowids
The list of overflow IDs. If row=<entity_type> is specified, this will be for the specific entity type in the include. If column=<idpool_number> is specified, row=<entity_type> must also be specified, and this will be for the specific entity type and ID pool. Valid for hm_getvalue query only.
Type: integer array
parent
The parent of the include. Valid for hm_getvalue query only.
Type: integer
parentid
Type: integer
range_offset
The ID range offset.
Type: integer
releaseidsconflictwithreserves
Release the list of reserved IDs. row=<entity_type> must be specified. If column=<idpool_number> is specified, this will be for the specific entity type and ID pool.
Type: integer array
releasereservedids
The list of release reserved IDs. row=<entity_type> must be specified. If column=<idpool_number> is specified, this will be for the specific entity type and ID pool. Valid for hm_getvalue query only.
Type: integer array
reserveidoption
The ID manager reserve ID option.
Type: string
reservedids
The list of reserved IDs. row=<entity_type> must be specified. If column=<idpool_number> is specified, this will be for the specific entity type and ID pool. Valid for hm_getvalue query only.
Type: integer array
reserverange
Type: integer
reserverangemax
The max of the reserve range. row=<entity_type> should be specified, this will be for the specific entity type in the include.
Type: integer
reserverangemin
The min of the reserve range. row=<entity_type> should be specified, this will be for the specific entity type in the include.
Type: integer
shortname
The short name of the include (name without path). Valid for hm_getvalue query only.
Type: string
showhidestate
The show/hide state on the submodel or excluded entities.
solverkeyword
The name of the solver keyword.
Type: string
supportedtypesandpools
The list of types and pool numbers which are supported by ID Manager. The return format is {-1 1 -2 3 …} where a negative number is the entity type while a positive number is the ID pool number. Valid for hm_getvalue query only.
Type: integer array
typesandpools
The list of types and pool numbers which are listed in the ID Manager. The return format is {-1 1 -2 3 …} where a negative number is the entity type while a positive number is the ID pool number. Valid for hm_getvalue query only.
Type: integer array
typesandpoolswithreservedids
The list of types and pool numbers which have reserved IDs. The return format is {-1 1 -2 3 …} where a negative number is the entity type while a positive number is the ID pool number. Valid for hm_getvalue query only.
Type: integer array
typesofexclusiveidranges
The types of exclusive ID ranges. Valid for hm_getvalue query only.
Type: integer array
typesofindividualidranges
The types of individual ID ranges under the submodel. Valid for hm_getvalue query only.
Type: integer array
typesundersubmodel
The type list under the submodel with active value on entity type, like idrange definition or entity count on the type. Valid for hm_getvalue query only.
Type: integer array
typeswithreservedids
The list of reserved ID entity types. If row=<entity_type> is specified, this will be for the specific entity type in the include. If column=<idpool_number> is specified, row=<entity_type> must also be specified, and this will be for the specific entity type and ID pool. Valid for hm_getvalue query only.
Type: integer array
unsettypesandpools
The list of types and pool numbers which do not have an ID range defined. The return format is {-1 1 -2 3 …} where a negative number is the entity type while a positive number is the ID pool number. Valid for hm_getvalue query only.
Type: integer array
write_protected
write_protected The write protected or "do not export" state. Valid for hm_getvalue query only.
Type: Boolean
Version History
2019 - Added new data names idlist, supportedtypesandpools, typesandpools, typesandpoolswithreservedids and unsettypesandpools.
2020 - Added new data name dirty_flag_for_export.
2020.1 - Added new data name solverkeyword.
