bodies
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
components
The list of components in an assembly (pointervalue is the component ID).
Type: entity array
config
The configuration of the entity.
11 - Heterogeneous bodies
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
fixed_dof
The degrees of freedom of the entity.
Type: array of integer
fixed_dof_system
The local coordinate system used to define fixed_dof.
Type: entity
fixedtoground
Flag specifying if the body is grounded or not.
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
morphhandles
The morph handles with move with the body.
Type: entity array
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
sets
The sets referred in the body.
Type: entity array
solverkeyword
The name of the solver keyword.
Type: string
Version History
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
2021 - Added new data name morphhandles.
