interfacelinkings
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
config
The configuration of the entity.
101 - LS-DYNA *INTERFACE_LINKING_DISCRETE_NODE_<OPTION>
102 - LS-DYNA *INTERFACE_LINKING_EDGE
103 - LS-DYNA *INTERFACE_LINKING_SEGMENT
104 - LS-DYNA *INTERFACE_LINKING_FILE
105 - LS-DYNA *INTERFACE_LINKING_NODE_<OPTION>
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
entityid
The node ID or node set ID to be moved by the interface file. This is supported for config 101, 102 and 105.
Type: entity
filename
The name of the file where the component data will be writen when config=104.
Type: string
fx
The ID of a *DEFINE_FUNCTION which determines the X direction displacement scale factor when config=105.
Type: entity
fy
The ID of a *DEFINE_FUNCTION which determines the Y direction displacement scale factor when config=105.
Type: entity
fz
The ID of a *DEFINE_FUNCTION which determines the Z direction displacement scale factor when config=105.
Type: entity
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
interfaceid
The interface ID in the interface file. This is supported for config 101 and 102.
Type: integer array
interfaceidlist
The list of interface IDs in the interface file. This is supported for config 103.
Type: integer
localflag
The flag to specify the local option when config=105.
Type: Boolean
locnode
The ID of the local node for transforming displacements when config=105.
Type: entity
locsystem
The ID of the local system for transforming displacements when config=105.
Type: entity
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
segmentids
The segment sets to be moved by the interface file. This is supported for config 103.
Type: entity array
segmentidsmax
The maximum number of segments referred.
solverkeyword
The name of the solver keyword.
Type: string
usecordinate
A flag to indicate the use of the coordinate system in the linking file during displacement transformation when config=105.
Type: entity
0 - Linking file coordinate system is not used
1 - Linking file coordinate system is used
usenode
A flag to indicate the use of the node displacement in the linking file during displacement transformation when config=105.
Type: entity
0 - Node displacement is not used
1 - Node displacement is used
Version History
2019
2019.1 - Added new data name filename.
2020 - Added new data name color_rgb.
2020.1 - Added new config values 104 and 105 and entityid support for config 105. Added new data names fx, fy, fz, localflag, locnode, locsystem, solverkeyword, usecordnate and usenode.
