interfacecomponents
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
cid
Coordinate system ID if config=101 or config=102.
Type: entity
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
101 - LS-DYNA *INTERFACE_COMPONENT_NODE
102 - LS-DYNA *INTERFACE_COMPONENT_SEGMENT
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
fileformat
The file format to use (optional) when config=103 .
1 - Use legacy binary file format
2 - Use new LSDA file format.
Type: integer
filename
The name of the file where the component data will be writen when config=103.
Type: string
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
name
The name of the entity.
Type: string
nid
The node ID for config=101 and config=102.
Type: entity
optionalcard
The flag to define the optional card for config=103.
Type: entity
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
setid
The *SET_NODE or *SET_SEGMENT node set ID.
Type: entity
solverkeyword
The name of the solver keyword.
Type: string
title
The _TITLE option.
Type: Boolean
Version History
2019
2019.1 - Added new data names cid, fileformat, filename, nid and optionalcard.
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
