elementclusters
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
201 - Radioss /CLUSTER
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
elem_type
The element type of the entity.
1 - Radioss /CLUSTER/BRICK
2 - Radioss /CLUSTER/SPRING
Type: integer
exponents_b1
Multidirectional failure exponent.
Type: double
exponents_b2
Type: double
exponents_b3
Type: double
exponents_b4
Type: double
fn_fail1
The node identifier.
Type: double
fs_fail
The x-coordinate of the normal vector tail.
Type: double
group_ID
The ID of the group identifier.
Type: entity
ifail
The failure model option.
Type: integer
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
mb_fail
The z-coordinate of the normal vector tail.
Type: double
mt_fail
The y-coordinate of the normal vector tail.
Type: double
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
scalefactor_a1
Multidirectional failure scale factor.
Type: double
scalefactor_a2
Type: double
scalefactor_a3
Type: double
scalefactor_a4
Type: double
skew_ID
The ID of the skew identifier.
Type: entity
solverkeyword
The name of the solver keyword.
Type: string
Version History
2019
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
