designpoints
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
attributesmax
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
designpointstrucelemid
The ID of the structural property.
Type: entity
entityids
The IDs of the entities.
Type: entity array
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
panellength
The calculated panel length if the design point contains panel entities.
Type: double
panelradius
The calculated panel radius if the design point contains panel entities.
Type: double
panelwidth
The calculated panel width if the design point contains panel entities.
Type: double
position
The coordinates of the location.
Type: triple double
projectentityids
The IDs of the projection entities.
Type: entity array
solverkeyword
The name of the solver keyword.
Type: string
system
The ID of the system.
Type: entity
Version History
2019.1
2020 - Added new data names activesuppressed, color_rgb, name, outputsuppressed, panellength, panelradius, panelwidth and position.
2020.1 - Added new data name solverkeyword.
