properties
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
cardimage
The name of the assigned card image.
Type: string
cardimagetype
The type of the assigned card image.
Type: string
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
encrypted
True if the entity is encrypted, false otherwise
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
laminate
The ID of the laminate linked to the property (e.g. /PROP/STACK or /PROP/TYPE51). This data name is not used for other properties in Radioss, nor at all in other profiles.
Type: entity
material
A pointer to the material assigned to the property. This will always be a valid material ID if one is assigned.
Type: pointer
materialid
The ID of the material assigned to the property. This could be a valid material ID or unresolved material ID.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
thickness
The thickness of the property. This is only available for "core" solver templates routinely maintained by Altair.
Type: double
Version History
2017.2 - Added new data name laminate.
2019 - Added new data name thickness.
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
