solvermasses
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
componentid
The ID of the part.
Type: entity
compxx
The XX component of the intertia tensor.
Type: double
compxy
The XY component of the intertia tensor.
Type: double
compxz
The XZ component of the intertia tensor.
Type: double
compyy
The YY component of the intertia tensor.
Type: double
compyz
The YZ component of the intertia tensor.
Type: double
compzz
The ZZ component of the intertia tensor.
Type: double
config
The configuration of the entity.
101 - LS-DYNA *ELEMENT_MASS child
102 - LS-DYNA *ELEMENT_MASS_NODE_SET
103 - LS-DYNA *ELEMENT_MASS_PART
104 - LS-DYNA *ELEMENT_MASS_PART_SET
105 - LS-DYNA *ELEMENT_MASS parent
106 - LS-DYNA *ELEMENT_INERTIA
201 - Radioss /ADMAS
csid
The ID of the coordinate system ID.
If 0, this uses the global inertia tensor. If >= 1, this uses the principal moments of inertias with orientation vectors defined by the given system.
Type: entity
curveid
The ID of the optional load curve ID to scale the added mass at time 0.
Type: entity
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
distribution
An optional flag for mass-weighted distribution, valid for SET option only:
0 - Non-structural mass is distributed by area (shell)/volume(solid) weighted distribution
1 - Non-structural mass is distributed by mass weighted area*density*thickness(shell)/volume*density(solid)) distribution.
Type: integer
entityids
The nodes or part IDs the mass is applied to.
Type: entity array
entityidsmax
The number of nodes or parts the mass is applied to.
Type: integer
finalmass
The final translational mass of the part ID or part set ID. The total mass of the PID or SID is computed and subtracted from the final mass of the part or part set to obtain the added translational mass, which must exceed zero.
Type: double
iflags
Flag to switch between area weighted distribution and volume weighted distribution of the added mass to parts.
Type: integer
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
location_unit_solvermass
The IDs of the child masses (config 101) for a parent mass (config 105).
Type: entity array
masses
The added mass value.
Type: double
name
The name of the entity.
Type: string
nodalgroupid
The ID of the parent mass (config 105) for child masses (config 101).
Type: entity
nodeid
The ID of the node to which the mass is assigned.
Type: entity
offsetoption
True to enable the OFFSET option for config 106.
Type: entity
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
setid
The ID of the node/surf/part set the mass is applied to.
Type: entity
solverkeyword
The name of the solver keyword.
Type: string
totalmass
Returns the total mass for config 105.
Valid for hm_getvalue query only.
Type: double
type
The type of solvermass.
0 - Mass is added to each node of node group.
1 - Mass/N is added to each node of node group, with N being the total number of nodes in the node group.
2 - Mass/Area - additional surface mass applied on the shell area
3 - Additional mass distributed on the part-group
4 - Final mass distributed on the part-group.
5 - Mass is added to each single node
6 - Additional mass distributed on each single part
7 - Final mass distributed on each single part.
Type: integer
xoffset
The x offset from the nodal point.
Type: double
yoffset
The y offset from the nodal point.
Type: double
zoffset
The z offset from the nodal point.
Type: double
Version History
2019
2020 - Added new data name color_rgb.
2020 - Added new config values 101-106. Added new data names componentid, compxx, compxy, compxz, compyy, compyz, compzz, csid, curveid, distribution, finalmass, location_unit_solvermass, nodalgroupid, nodeid, offsetoption, totalmass, xoffset, yoffset and zoffset.
2020.1 - Added new data name solverkeyword.
