morphconstraints
Unless otherwise specified, data names are accessible in level 3 only.
active
The morph constraint active flag 0/1.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
name
The name of the entity.
Type: string
nnode
The number of constrained nodes.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
type
The type of morph constraint.
  • 0 - fixed
  • 1 - vector
  • 2 - line
  • 3 - plane
  • 4 - surface
  • 5 - mesh
  • 6 - fixed with stretching
  • 7 - cluster
  • 8 - smooth
  • 9 - cluster with stretching
  • 11 - vector with limit
  • 12 - line with limit
  • 13 - plane with limit
  • 14 - surface with limit
  • 15 - mesh with limit
  • 20 - tangency
  • 30 - model
Type: integer
Version History
2020.1 - Added new data name solverkeyword.
