outputblocks
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
cardimage
The name of the assigned card image.
Type: string
cardimagetype
The type of the assigned card image.
Type: string
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
element
Pointer to the elements in the outputblock for outputblocks containing elements.
Type: Use with pointer - pointer1.element.id
entitytype
The type of the outputblock.
  • 1 - node
  • 2 - element
  • 3 - component
  • 4 - material
  • 5 - group
  • 6 - system
  • 7 - set
Type: integer
id
The ID of the entity.
ids
Pointer to the entity IDs.
Type: pointer(value is entity ID)
idsmax
The maximum number of IDs.
Type: integer
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
set
Pointer to the set for sets of sets for outputblocks containing sets.
Type: pointer
solverkeyword
The name of the solver keyword.
Type: string
type
The solver dependent type code for the entity.
Type: integer
typename
The solver dependent type name for the entity.
Type: string
Version History
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
