terminations
Unless otherwise specified, data names are accessible in level 3 only.
actim
The termination activation time. Valid for config 102.
Type: double
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
atime
The termination activation time. Valid for config 103.
Type: double
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
cid
The termination contact ID. No CONTACT_2D allowed. Valid for config 102.
Type: entity
config
The configuration of the entity.
101 - LS-DYNA *ALE_REFERENCE_SYSTEM_GROUP
101 - LS-DYNA *TERMINATION_BODY
102 - LS-DYNA*TERMINATION_CONTACT
103 - LS-DYNA *TERMINATION_CURVE
104 - LS-DYNA *TERMINATION_DELETED_SHELLS
105 - LS-DYNA *TERMINATION_ DELETED_SOLIDS
106 - LS-DYNA *TERMINATION_NODE
107 - LS-DYNA *TERMINATION_SENSOR
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
dof
The termination option to consider only the force magnitude in the x, y, or z global directions corresponding to DOF 1,2, and 3 respectively. Valid for config 102.
Type: integer
dur
The termination time duration of the null resultant force prior to termination. Valid for config 102.
Type: double
entityId
The termination part ID or part set ID. Valid for config 104 and 105.
Type: entity
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
lcid
The termination load curve ID. Valid for config 103.
Type: entity
maxc
The termination maximum (most positive) displacement. Must be greater than minc. Valid for config 101.
Type: double
minc
The termination minimum (most negative) displacement. Must be less than maxc. Valid for config 101.
Type: double
name
The name of the entity.
Type: string
nds
The number of elements that must be deleted for the specified part IDs before an error termination occurs. Valid for config 104 and 105.
Type: integer
nid
The termination node ID. Valid for config 106.
Type: entity
nmaxc
The termination maximum (most positive) coordinate. Must be greater than nminc. Valid for config 106.
Type: double
nminc
The termination minimum (most negative) coordinate. Must be less than nmaxc. Valid for config 106.
Type: double
nstop
The termination stop criterion. Valid for config 106.
Type: integer
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
pid
The termination part ID of the rigid body. Valid for config 101.
Type: entity
solverkeyword
The name of the solver keyword.
Type: string
stop
The termination stop criterion. Valid for config 101.
Type: integer
swid
The termination ID of LS-DYNA*SENSOR_SWITCH which will terminate the calculation when its condition is met. Only one is allowed. If more than one is defined, only the last one is effective. Valid for config 107.
Type: entity
thres
The termination threshold. Valid for config 102.
Type: double
Version History
2019
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
