attachmentcontrols
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
1 - Rigid spider
2 - Rigid patch
connectouterlayer
The way to connect to the hole for config 1.
Type: string
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
elemtype
The element type name for config 1.
Type: string
engname
The engineering name.
Type: string
findhole
0 - Do not find a hole
1 - Find a hole
Type: Boolean
holeandwasher
The option to fill hole or use washer elements for config 2.
Type: string
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
maxdia
The maximum diameter for finding a hole when findhole is 1.
Type: double
mindia
The minimum diameter for finding a hole when findhole is 1.
Type: double
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
Version History
2020
2020.1 - Added new data name solverkeyword.
