rigidbodies
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
alpha
The thermal expansion coefficient when config=303.
Type: double
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
centerofgravity
The COG x, y and z coordinates.
Type: triple double
centerofgravity_x
The COG x coordinate.
Type: double
centerofgravity_y
The COG y coordinate.
Type: double
centerofgravity_z
The COG z coordinate.
Type: double
cogdefined
0 - COG is not defined
1 - COG is defined
Type: Boolean
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
301 - OptiStruct RBODY
302 - OptiStruct RBADD
coordinatesystem
The ID of the coordinate system to define the orientation of the inertia tensor.
Type: entity
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
dofstring
The component number of dependent degrees-of-freedom for grid GM when config=303.
Type: string
dof1
The degree-of-freedom for component 1 for config=303.
Type: Boolean
dof2
The degree-of-freedom for component 2 for config=303.
Type: Boolean
dof3
The degree-of-freedom for component 3 for config=303.
Type: Boolean
dof4
The degree-of-freedom for component 4 for config=303.
Type: Boolean
dof5
The degree-of-freedom for component 5 for config=303.
Type: Boolean
dof6
The degree-of-freedom for component 6 for config=303.
Type: Boolean
elementsetcount
The count of referenced element sets when config is 301.
Type: integer
elementsets
The list of referenced element sets when config is 301.
Type: entity array
GMj
The list of grids to be excluded from candidate grids for GM when config=303.
Type: entity array
gmjcount
The number of GMj in RBE2GS when config=303.
GNi
The list of grids to be excluded from candidate grids for GN when config=303.
Type: entity array
gnicount
The number of GNi in RBE2GS when config=303.
gs
Search POINT or GRID point when config=303.
Type: entity
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
inertiadefined
0 - Inertia is not defined
1 - Inertia is defined
Type: Boolean
internalid
IXX
The Ixx component of inertia.
Type: double
IXY
The Ixy component of inertia.
Type: double
IXZ
The Ixz component of inertia.
Type: double
IYY
The Iyy component of inertia.
Type: double
IYZ
The Iyz component of inertia.
Type: double
IZZ
The Izz component of inertia.
Type: double
mass
The defined mass value.
Type: double
massdefined
0 - Mass is not defined
1 - Mass is defined
Type: Boolean
name
The name of the entity.
Type: string
nodesetcount
The count of referenced grid sets when config is 301.
Type: integer
nodesets
The list of referenced grid sets when config is 301.
Type: entity array
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
radius
The radius when config=303.
Type: double
referencenode
The ID of the reference node.
Type: entity
rigidbodies
The list of referenced rigidbodies when config is 302.
Type: entity array
rigidbodycount
The count of referenced rigidbodies when config is 302.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
surfacecount
The count of referenced contact surfaces when config is 301.
Type: integer
surfaces
The list of referenced contact surfaces when config is 301.
Type: entity array
type
Connectivity when config=303.
1 - NMFLIP
2 - IIRBE2
3 - NMIIRBE2
uniqueid_rbe2gs
The unique ID for RBE2GS type RigidBody when config=303.
xs
The x location search point when config=303.
Type: double
ys
The y location search point when config=303.
Type: double
zs
The z location search point when config=303.
Type: double
Version History
2017.2
2019.1 - Added new data names alpha, dofstring, dof1, dof2, dof3, dof4, dof5, dof6, GMj, gmjcount, GNi, gnicount, gs, radius, type, uniqueid_rbe2gs, xs, ys and zs.
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
