geometricrepresentations
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
boundingboxlowercorner
The coordinates of the lower corner of the box in the global system.
Type: triple double
boundingboxuppercorner
The coordinates of the upper corner of the box in the global system.
Type: triple double
boxdimensions
The length (along x axis), width (along y axis) and height (along z axis) of the box.
Type: triple double
collectioncentroid
The coordinates of the centroid of the entities found within the box.
Type: triple double
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
entitycollection
The IDs of the entities bound by the box.
Type: entity array
excludeentities
The IDs of the entities to exclude from the box.
Type: entity array
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
systemaxis
The values of the 3x3 matrix that orients the local coordinate system of the box at the lower corner expressed in the global axis system.
Type: 3x3 matrix
Version History
2021
