frictions
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- c1
- The default c1 friction law coefficient.
- c1_2
- The c1_2 friction law coefficient.
- c1_part
- The c1 friction law coefficient for specific parts or groups of parts.
- c2
- The default c2 friction law coefficient.
- c2_2
- The c2_2 friction law coefficient.
- c2_part
- The c2 friction law coefficient for specific parts or groups of parts.
- c3
- The default c3 friction law coefficient.
- c3_2
- The c3_2 friction law coefficient.
- c3_part
- The c3 friction law coefficient for specific parts or groups of parts.
- c4
- The default c4 friction law coefficient.
- c4_2
- The c4_2 friction law coefficient.
- c4_part
- The c4 friction law coefficient for specific parts or groups of parts.
- c5
- The default c5 friction law coefficient.
- c5_2
- The c5_2 friction law coefficient.
- c5_part
- The c5 friction law coefficient for specific parts or groups of parts.
- c6
- The default c6 friction law coefficient.
- c6_2
- The c6_2 friction law coefficient.
- c6_part
- The c6 friction law coefficient for specific parts or groups of parts.
- cid
- The contact ID to optinally limit friction scaling to one contact interface.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity.
- dc_d
- The default value of the exponential decay coefficent.
- dc_ij
- The exponential decay coefficent between parts i and j.
- definedentity
- True if the entity is defined, false otherwise.
- e_coef
- The damping coefficient of the exponential function.
- elastic_slip
- The amount of allowable slip.
- fd_d
- The default value of the dynamic coefficent of friction.
- fd_ij
- The dynamic coefficent of friction between parts i and j.
- fric
- The Coulomb friction value.
- fric_2
- fric_part
- The Coulomb friction value for specific parts or groups of parts.
- friction
- The friction_type friction coefficient.
- friction_format
- Specifies how friction is defined:
- friction_style
- When friction_format is 1, specifies the reference variable:
- friction_table
- When friction_format is 1, specifies the ID of the table containing friction_style values vs friction_type friction.
- friction_type
- Specifies the type of friction:
- fs_d
- The default value of the static coefficent of friction.
- fs_ij
- The static coefficent of friction between parts i and j.
- grpart_ID1
- The first part set identifier.
- grpart_ID2
- The second part set identifier.
- Grpart_Part_Type
- The Grpart/Part type selector:
- icnep
- The flag to check for non-existing parts, or part sets:
- id
- The ID of the entity.
- Idir
- The flag for orthotropic friction:
- ifiltr
- The friction filtering flag:
- iform
- The friction penalty formulation type:
- ifric
- The friction formulation flag:
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- lcid
- The ID of the load curve defining the coefficient of friction vs orientation angle.
- lcidp
- The ID of the load curve defining the coefficient of friction vs pressure.
- iorth
- The orthotropic system formulation flags for reference vector:
- max_shear
- The maximum shear stress when maxshear_format is 0.
- maxshear_format
- Determines how the maximum shear stress is defined:
- maxshear_style
- When maxshear_format is 1, specifies the reference variable:
- maxshear_table
- When maxshear_format is 1, specifies the ID of the table containing maxshear_style values vs maximum shear stress.
- N
- The number of friction values for specific parts or groups of parts.
- name
- The name of the entity.
- n_orient
- The number of friction orientations.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- part_ID1
- The first part identifier.
- part_ID2
- The second part identifier.
- phi
- The angle.
- pid
- The part ID to which directional and pressure-sensitive coefficient of friction is to be applied.
- psid
- The part set ID to optionally limit friction scaling to parts in the set.
- ptype_i
- The part i entity type:
- ptype_j
- The part j entity type:
- scalei
- The friction scale factor for the inner surface of the shell elements.
- scaleo
- The friction scale factor for the outer surface of the shell elements.
- skew_id
- The skew identifier for reference vector.
- slip_tolerance
- The allowable slip tolerance.
- solverkeyword
- The name of the solver keyword.
- v1
- The 1-component of the vector defining the 0-degree direction.
- v2
- The 2-component of the vector defining the 0-degree direction.
- v3
- The 3-component of the vector defining the 0-degree direction.
- vc_d
- The default value of the viscous friction coefficent.
- vc_ij
- The viscous friction coefficent between parts i and j.
- vis_f
- The default value of critcal damping coefficient on interface friction.
- vis_f_2
- The critcal damping coefficient on interface friction.
- vis_f_part
- The default value of critcal damping coefficient on interface friction for specific parts or groups of parts.
- vx
- The x component for reference vector.
- vy
- The y component for reference vector.
- vz
- The z component for reference vector.
- xfreq
- The filtering coefficient.
Version History
2020
2020.1 - Added new data names c1_2, c2_2, c3_2, c4_2, c5_2, c6_2, e_coef, elastic_slip, fric_2, friction, friction_format, friction_style, friction_table, friction_type, Grpart_Part_Type, Idor, iorthmax_shear, maxshear_format, maxshear_style, maxshear_table, n_orient, phi, slip_tolerance, skew_id, solverkeyword, vis_f_2, vx, vy and vz. Added new config value 601.
2021 - Added new data names cid, icnep, psid, scalei and scaleo.
