accelerometers
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
config
The configuration of the entity.
101 - LS-DYNA *ELEMENT_SEATBELT_ACCELEROMETER
201 - Radioss /ACCEL
curve_id
If igrav_gt is true, the ID of the curve defining the gravitation flag vs time.
Type: entity
cutoff
The cutoff frequency.
Type: double
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
id
The ID of the entity.
igrav
If igrav_gt is false, the gravitational accelerations due to body force loads.
Type: integer
igrav_gt
If true, IGRAV converts to a curve and curve_id is used.
Type: Boolean
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
intopt
The integration option.
Type: integer
mass
The added mass.
Type: double
multi_nodes
The IDs of the base, x-axis and x-y plane nodes. Valid for hm_getvalue query only.
Type: entity array
name
The name of the entity.
Type: string
node1
The ID of the base node.
Type: entity
node2
The ID of the x-axis node.
Type: entity
node3
The ID of the x-y plane node.
Type: entity
nodeid
The ID of the accelerometer base node.
Type: entity
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
skewid
The ID of the skew node.
Type: entity
solverkeyword
The name of the solver keyword.
Type: string
Version History
2019 - Added new data names cutoff, nodeid and skewid. Added config 201.
2020 - Added new data names color_rgb, curve_id and igrav_gt.
2020.1 - Added new data name solverkeyword.
