freebodygroups
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
fbdlist
The IDs of the FBD entities.
Type: entity array
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
intersectentityids
The IDs of the intersect entities.
Type: entity array
intersectentitytype
The type of the intersect entities.
2 - Elements
name
The name of the entity.
Type: string
orientationvector
The orientation vector coordiates when systemdef is 2.
Type: triple double
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
system
The ID of the system entity when systemdef is 1.
Type: entity
systemdef
The system definition type:
0 - Global
1 - User-defined
2 - Direction-based
Type: string
Version History
2019.1
2020 - Added new data names color_rgb, orientationvector and systemdef. The resolve data name has been removed and replaced by the systemdef data name. The behavior of the system data name is now dependent on the systemdef data name.
2020.1 - Added new data name solverkeyword.
