positions
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
applied
1 if the position is applied, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
config
The configuration of the entity.
1 - Pair list
2 - Body list
3 - Entity list field
101 - LS-DYNA *DEFINE_TRANSFORMATION and *NODE_TRANSFORM
201 - Set or submodel
401 - PAM-CRASH IMPORT
402 - PAM-CRASH EXPORT
403 - PAM-CRASH IMPFIL
404 - PAM-CRASH PICIMP
405 - PAM-CRASH PICEXP
406 - PAM-CRASH PICK
407 - PAM-CRASH TRSFM
501 - Entity list
dataval
The export data keyword.
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
export_string
The export parameter string.
Type: string
exportdatavaluemax
The tabular data support for export data.
htf
The heat treatment coefficient.
Type: double
id
The ID of the entity.
idoptlis
The ID of the option list selection definition.
Type: entity
ifile
The flag for the mapping file format.
impfil_fname
The name of the mapping file.
Type: string
impfil_path
The directory path of the mapping file.
Type: string
importname
The name of image part.
Type: string
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
ioutfram
The 2K local frame file format activation.
ipf
The process flag.
iplot
The check file option flag.
mechanism
The parent mechanism of the position.
Type: entity
name
The name of the entity.
Type: string
numberofsourcecontrolmax
The tabular data support for source control.
optlis_selection
The option list selection definition keyword.
Type: Boolean
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
picexp_export_control
The picking export control keyword.
Type: Boolean
picexp_export_control_qualifier
The picking export control definition.
picexp_export_control_switch
Activation/deactivation of the picking export control option.
picexp_export_limit
The export limit definition keyword.
Type: Boolean
picexp_export_point
The export point definition keyword.
Type: Boolean
picexp_exportpoint_qualifier
The definition of the output frequency of the picking file.
picexp_exportpoint_value1
The time value depending on the output frequency type specified by picexp_exportpoint_qualifier.
Type: double
picexp_exportpoint_value2
Type: double
picexp_exportpoint_value3
Type: double
picexp_exportpoint_value4
Type: double
picexp_exportpoint_value5
Type: double
picexp_exportpoint_value6
Type: double
picexp_namepicexp
The name of the root file where the picking database will be stored.
Type: string
picexp_write
The picking export file name keyword.
Type: string
picimp_picmax
The maximum number of picking files to be created.
Type: integer
picimp_read
The picking import file keyword.
Type: string
picimp_sidele
The shift to apply to source element identification numbers.
Type: integer
picimp_sidnod
The shift to apply to source node identification numbers.
Type: integer
picimp_smodule
The source module identification path.
Type: string
picimp_source_control
The user-selected picking control keyword card.
Type: Boolean
picimp_source_control_qualifier
The picking control keyword definition.
picimp_source_control_switch
Activation/deactivation of the picking control option.
picimp_source_module
The keyword for defining the source module where entities will be found.
Type: Boolean
picimp_source_shift_idele
The source elements shift definition keyword.
Type: Boolean
picimp_source_shift_idnod
The source nodes shift definition keyword.
Type: Boolean
picimp_sourcefile
The root file name.
Type: string
pick_mppn
The number of processors used in the previous computation to create restart files having the same pick_name.
Type: integer
pick_name
The restart file name.
Type: string
pick_restartfile
The restart file keyword.
Type: string
pick_time
The picking time keyword.
Type: Boolean
pick_timevalue
The picking time value in the restart file.
Type: double
rdist
The search extension for identification of all image elements which are close to target element.
Type: double
sets
The general entity selection set.
Type: entity
sets_count
The set count.
Type: integer
shellvartype1
The shell variable keyword1 data values.
shellvartype2
The shell variable keyword2 data values.
Shellvartypemax
The tabular data support for the shell variable.
solverkeyword
The name of the solver keyword.
Type: string
Title
Append _TITLE to *DEFINE_TRANSFORMATION keyword.
Type: Boolean
transformations
The transformation entities the position is/can be applied to.
transformations_count
The number of transformation entities the position is/can be applied to.
Type: integer
vars
The shell variable card keyword.
Type: Boolean
varv
The volume element variable card keyword.
Type: Boolean
volumeeletype1
The volume element variable keyword1 data values.
volumeeletype2
The volume element variable keyword2 data values.
volumeeletypemax
The tabular data support for the volume variable.
Version History
2019 - Added new data names dataval, export_string, exportdatavaluemax, htf, ifile, impfil_fname, impfil_path, importname, ioutfram, ipf, iplot, numberofsourcecontrolmax, picexp_export_limit, picexp_export_point, picexp_exportpoint_qualifier, picexp_exportpoint_value1, picexp_exportpoint_value2, picexp_exportpoint_value3, picexp_exportpoint_value4, picexp_exportpoint_value5, picexp_exportpoint_value6, picexp_namepicexp, picexp_write, picimp_picmax, picimp_read, picimp_sidele, picimp_sidnod, picimp_smodule, picimp_source_control, picimp_source_control_qualifier, picimp_source_control_switch, picimp_source_module, picimp_source_shift_idele, picimp_source_shift_idnod, picimp_sourcefile, pick_mppn, pick_name, pick_restartfile, pick_time, pick_timevalue, rdist, sets, sets_count, shellvartype1, shellvartype2, Shellvartypemax, vars, varv, volumeeletype1, volumeeletype2 and volumeeletypemax.
2019.1 - Added new config values 101 and 407. Added new data names picexp_export_control, picexp_export_control_qualifier, picexp_export_control_switch and Title.
2020.1 - Added new data names idoptlis, optlis_selection and solverkeyword.
