morphvolumes
Unless otherwise specified, data names are accessible in level 3 only.
aid
The internal ID of the morph volume.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
edgeids
The internal IDs of the twelve edges of the entity. Valid for hm_getvalue query only.
Type: integer array
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
nodeids
The IDs of the eight corner nodes of the entity. Valid for hm_getvalue query only.
Type: entity array
solverkeyword
The name of the solver keyword.
Type: string
Version History
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
