points
Unless otherwise specified, data names are accessible in level 3 only.
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
collector
Pointer to the collector that owns the element.
Type: pointer (levels 2, 3 and 4)
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
geomid
The internal ID in the geometry database.
Type: integer
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
solverkeyword
The name of the solver keyword.
Type: string
x
The x coordinate of the point.
Type: double
y
The y coordinate of the point.
Type: double
z
The z coordinate of the point.
Type: double
Version History
2020.1 - Added new data name solverkeyword.
