constrainedextranodes
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
101 - LS-DYNA *CONSTRAINED_EXTRA_NODES_NODE
102 - LS-DYNA *CONSTRAINED_EXTRA_NODES_SET
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
entityid
The ID of the node or set, based on config.
Type: integer
id
The ID of the entity.
iflag
0 - Inertia properties of the Part ID are not defined in PART_INTERTIA.
1 - Inertia properties of the Part ID are defined in PART_INTERTIA.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
Version History
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
