loadsteps
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
cardimage
The name of the assigned card image.
Type: string
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
contactgroups_ids
Pointer to the contact groups in the loadstep.
Type: pointer(value is group ID)
contactgroups_idsmax
The number of contact groups in the loadstep.
Type: integer
curve_ids
Pointer to the curves in the loadstep.
Type: pointer(value is curve ID)
curve_idsmax
The number of curves in the loadstep.
Type: integer
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
groups_ids
Pointer to the groups in the loadstep.
groups_idsmax
The number of groups in the loadstep.
Type: integer
id
The ID of the entity.
ids
Pointer to the loadcols in the loadstep.
Type: pointer(valid is loadcol ID)
idsmax
The number of loadcols in the loadstep.
Type: integer
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
loadcollector
Pointer to the loadcollector.
Type: pointer(- pointer1.loadcollector.id)
name
The name of the entity.
Type: string
ob_ids
Pointer to the outputblock in the loadstep.
Type: pointer(value is outputblock ID)
ob_idsmax
The number of outputblocks in the loadstep.
Type: integer
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
Version History
2020 - Added new data names color_rgb. contactgroups_ids and contactgroups_idsmax.
2020.1 - Added new data name solverkeyword.
2021 - Added new data names curve_ids and curve_idsmax.
