velocities
Unless otherwise specified, data names are accessible in level 3 only.
engineering_type
The engineering type of load. Engineering loads act on set entities. Valid values are:
0 - Classic load
2 - Normal engineering load
3 - Directional engineering load
Type: unsigned integer
The following data names are available for both classic and engineering loads:
attributesmax
The number of attributes owned by this entity.
collector
Pointer to the collector that owns the element.
Type: pointer (levels 2, 3 and 4)
config
The configuration of the entity.
8 - Velocity
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
entityid
The ID of the entity the load is attached to.
Type: integer
entitytype
The type of the entity to which the load is applied.
  • 1 - node
  • 3 - comp
  • 5 - surf
  • 10 - set
  • 27 - point
  • 28 - line
Type: integer
entitytypename
The string type of the entity to which the load is applied.
  • nodes
  • comps
  • surfs
  • sets
  • points
  • lines
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
set
Pointer to the set when the load is applied to a set.
Type: pointer
solverkeyword
The name of the solver keyword.
Type: string
type
The solver dependent type code for the entity.
Type: integer
typename
The solver dependent type name for the entity.
Type: string
vectorx
The x component of the unit vector in the global coordinate system.
Type: double
vectory
The y component of the unit vector in the global coordinate system.
Type: double
vectorz
The z component of the unit vector in the global coordinate system.
Type: double
The following data names are available for classic loads:
baselocation
The coordinates where the load on a component or set should display. Valid for hm_getvalue query only.
Also used to convert the load vector components into local values for non-rectangular coordinate systems.
Type: triple double
baselocationx
The x-coordinate where the load on a component or set should display.
Type: double
baselocationy
The y-coordinate where the load on a component or set should display.
Type: double
baselocationz
The z-coordinate where the load on a component or set should display.
Type: double
comp1
The x component of the vector in the global coordinate system.
Type: double
comp2
The y component of the vector in the global coordinate system.
Type: double
comp3
The z component of the vector in the global coordinate system.
Type: double
component
Pointer to the component when the load is applied to a component.
Type: pointer
curveid
The ID of the curve defining the load magnitude when a curve has been used to define the load.
Type: integer
inputsystem
Pointer to the reference system.
Type: pointer
inputsystemid
The ID of the reference system.
Type: integer
local_comp1
The x component of the vector in the local coordinate system.
Type: double
local_comp2
The y component of the vector in the local coordinate system.
Type: double
local_comp3
The z component of the vector in the local coordinate system.
Type: double
local_vector
The load vector in the local coordinate system.
Type: triple double
local_vectorx
The x component of the unit vector in the local coordinate system.
Type: double
local_vectory
The y component of the unit vector in the local coordinate system.
Type: double
local_vectorz
The z component of the unit vector in the local coordinate system.
Type: double
location
The ID of the node where the load is applied. Valid for hm_getvalue query only.
Type: entity
magnitude
The magnitude of the vector
Type: double
mappedid
The ID of the original load on geometry.
Type: integer
node
Pointer to the node when the load is applied to a node.
Type: pointer
vector
The component of the unit vector. Valid for hm_getvalue query only.
Type: triple double
xscale
The x scale or time scale of the load curve when a curve has been used to define the load.
Type: double
The following data names are available for engineering loads:
compx
The dot product of the load vector projected on the global x axis.
Type: double
compy
The dot product of the load vector projected on the global y axis.
Type: double
compz
The dot product of the load vector projected on the global z axis.
Type: double
distribution_table_count
The number of rows of a non-uniform engineering load.
field
The field entity that stores the tabular load data.
Type: entity
location_unit_node
The nodes for which the data is stored in the table for a non-uniform engineering load.
Type: entity array
orient
The load orientation vector.
Type: triple double
orientx
The x component of the load orientation vector.
Type: double
orienty
The y component of the load orientation vector.
Type: double
orientz
The z component of the load orientation vector.
Type: double
resultant_magnitude
The resultant scalar component of the load vector in the global coordiante system.
Type: double
The following data names are available for Radioss engineering loads:
curveid
The ID of the time function identifier curve.
Type: entity
displayname
The text for the title entry.
Type: string
distribution
The spring specification for IMPVEL_FGEO:
0 - Spring part selection
1 - Final node positions
inputsystem
The skew/frame identifier.
Type: entity
magnitude
The ordinate (velocity) scale factor for fct_ID (default 1.0).
Type: double
rad_dir
The direction X, Y, or Z for translation or XX, YY, or ZZ for rotation.
Type: string
rad_dmin
The distance between node ID N and node ID N', which are rigidly connected.
Type: double
rad_ebcs_c
The speed of sound (default 0.0).
Type: double
rad_ebcs_fscale_en
The energy scale factor (default 0.0).
Type: double
rad_ebcs_fscale_pr
The pressure scale factor (default 0.0).
Type: double
rad_ebcs_fscale_rho
The density scale factor (default 0.0).
Type: double
rad_ebcs_fscale_vx
The x velocity scale factor (default 0.0).
Type: double
rad_ebcs_fscale_vy
The y velocity scale factor (default 0.0).
Type: double
rad_ebcs_fscale_vz
The z velocity scale factor (default 0.0).
Type: double
rad_ebcs_lc
The characteristic length (default 0.0).
Type: double
rad_ebcs_r1
The linear resistance (default 0.0).
Type: double
rad_ebcs_r2
The quadratic resistance (default 0.0).
Type: double
rad_ebcs_rho
The initial density (default 0.0).
Type: double
rad_fct_en
The function identifier for energy.
Type: entity
rad_fct_l_id
The load time function identifier.
Type: entity
rad_fct_pr
The function identifier for pressure.
Type: entity
rad_fct_rho
The function identifier for density.
Type: entity
rad_fct_vx
The function identifier for x velocity.
Type: entity
rad_fct_vy
The function identifier for y velocity.
Type: entity
rad_fct_vz
The function identifier for z velocity.
Type: entity
rad_icoor
The coordinate system type:
0 - Cartesian
1 - Cylindrical
Type: integer
rad_inivel_type
Enables selection of INIVEL type:
GRID - Grid material velocity (only for ALE material)
ROT - Rotational material velocity
T+G - Translational and grid material velocity *only for ALE material)
TRA - Translational material velocity
Type: string
rad_node_id
The node identifier giving the final position of the node.
Type: entity
rad_rotational_velocity
The rotational velocity about the rotational axis.
Type: double
rad_sensor_id
The ID of the sensor entity.
Type: entity
rad_spring_part
The spring part identifier.
Type: entity
rad_system_input_type
The system input type:
0 - Skew
1 - Frame
rad_t0
The time duration.
Type: double
rad_tstart
The start time.
Type: double
rad_tstop
The stop time (default 10^30).
Type: double
vector
The velocity vector.
Type: triple double
xscale
The abscissa (time) scale factor for fct_IDT (default 1.0).
Type: double
Version History
2020 - New support for engineering loads. Added new data names compx, compy, compz, displayname, distribution, distribution_table_count, engineering_type, field, local_comp1, local_comp2, local_comp3, local_vector, local_vectorx, local_vectory, local_vectorz, location, location_unit_node, orient, orientx, orienty, orientz, rad_dir, rad_dmin, rad_ebcs_c, rad_ebcs_fscale_en, rad_ebcs_fscale_pr, rad_ebcs_fscale_rho, rad_ebcs_fscale_vx, rad_ebcs_fscale_vy, rad_ebcs_fscale_vz, rad_ebcs_lc, rad_ebcs_r1, rad_ebcs_r2, rad_ebcs_rho, rad_fct_l_id, rad_fct_en, rad_fct_pr, rad_fct_rho, rad_fct_vx, rad_fct_vy, rad_fct_vz, rad_icoor, rad_inivel_type, rad_node_id, rad_sensor_id, rad_spring_part, rad_system_input_type, rad_t0, rad_rotational_velocity, rad_tstart, rad_tstop and resultant_magnitude.
2020.1 - Added new data name solverkeyword.
