rbe3
Unless otherwise specified, data names are accessible in level 3 only.
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
centerx
The x coordinate of the element centroid.
Type: double
centery
The y coordinate of the element centroid.
Type: double
centerz
The z coordinate of the element centroid.
Type: double
collector
Pointer to the collector that owns the element.
Type: pointer (levels 2, 3 and 4)
config
The configuration of the entity.
56 - rbe3
dependentcoeff
The dependent coefficient/weighting factor.
Type: double
dependentdof
The dependent node degrees of freedom, consisting of the values 1-6.
Type: integer
dependentnode
Pointer to the dependent node.
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
dofs
The degrees of freedom at the dependent node, consisting of the values 1-6. Type: integer.
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
independentcoeffs
Pointer to the independent coefficients.
independentcoeffsmax
The number of independent coefficients.
Type: integer
independentdofs
Pointer to the independent degrees of freedom.
independentdofsmax
The number of independent degrees of freedom.
Type: integer
independentnodes
Pointer to the independent nodes.
independentnodesmax
The number of independent nodes.
nodecount
The number of nodes for the element. Valid for hm_getvalue query only.
Type: integer
nodes
The list of nodes for the element. Valid for hm_getvalue query only.
Type: entity array
solverkeyword
The name of the solver keyword.
Type: string
type
The solver dependent type code for the entity.
Type: integer
typename
The solver dependent type name for the entity.
Type: string
Version History
2020.1 - Added new data name solverkeyword.
