TRAKMETH |
<0,
1, 2>Defaults:
- The value of this parameter is 0 if it
is not included in input file.
- If this parameter is included in the input file, but no
value is provided, then running the program will result
in an error.
TRAKMETH is a parameter that can be used to
select the criterion employed for mode tracking.There are three
tracking criteria available for selection in the current
implementation:
- Mass cross-orthogonality check (CORC)
- Modal assurance criterion (MAC)
- Modal assurance criterion square root (MACSR)
- 0 (Default)
- The Mass cross-orthogonality check (CORC) criterion
is used for mode tracking. This performs a mass
orthogonality check of the current and previous
eigenvectors after reanalysis. CORC is implemented
as:
- 1
- The Modal assurance criterion square root (MACSR)
criterion is used for mode tracking. This criterion
essentially calculates the dot product of the two
unit vectors associated with the current and
previous eigenvectors. MACSR is implemented as:
- 2
- The standard modal assurance criterion (MAC) is used
for mode tracking. MAC is implemented as:
- Where,
- Current eigenvector.
- Previous eigenvector.
- Mass matrix.
