NLENRG
Bulk Data Entry Defines parameters for energy variables printout for implicit nonlinear static, implicit nonlinear transient analyses, and explicit dynamic analysis.
| NLENRG | ID | PARAMi | VALUEi |
| “ESET” | SET1 | SET2 | etc. |
| “CONTACT” | CID1 | CID2 | etc. |
| “PGAP” | PGID1 | PGID2 | etc. |
| NLENRG | 99 | FREQ | 2 | ||||||
| ESET | 1001 | 1002 | |||||||
| CONTACT | ALL | ||||||||
| PGAP | 100 | 200 |
| ID | Each NLENRG Bulk Data Entry must have a
unique ID. No default (Integer > 0) |
| PARAMi | Name of parameter. | |
| VALUEi | Value of parameter. | |
| ESET | Keyword indicating energy variables are to be printed for selected element SETs. | |
| SETi | Element SET identification number. No default (Integer > 0) |
| CONTACT | Keyword indicating energy variables are to be printed for selected contact interfaces. | |
| CIDi |
No default |
| PGAP | Keyword indicating energy variables are to be printed for selected CGAP/CGAPG elements. | |
| PGIDi |
No default |
| PARAMi | VALUEi | SI Unit Example |
| FREQ | Output frequency in increments. Default = 1 (for Implicit analysis) Default = 100 (for Explicit analysis) (Integer > 0) |
| HG | Control for output of HyperGraph
data files (*.nlm). 3
4
- The NLENRG Bulk Data Entry is selected by the NLENRG Subcase Information command. In the following comments, filename implies the actual name of the input file or model.
- The energy variables are printed into the filename_e.out file for all nonlinear subcases.
- HyperGraph data file for the global energy variables,
if activated is named as filename_s<n>_e.nlm for
each nonlinear subcase; where, <n> denotes the
subcase ID. HyperGraph data file for the per-entity energy variables, if activated is named as for each entity in each nonlinear subcase:
- filename_eset<ID>_s<n>_e.nlm
- filename_cont<ID>_s<n>_e.nlm
- filename_pgap<ID>_s<n>_e.nlm
Where,- <ID>
- Denotes the entity ID
- <n>
- Denotes the subcase ID
The files *.nlm can be read and plotted by HyperGraph and, a HyperGraph session file named filename_energy.mvw is created for straightforward plotting of the global energy variables.
- For an implicit nonlinear subcase, if NLENRG entry is not defined, the global energy variables are written into a HyperGraph data file (filename_s<n>_e.nlm) for each time increment. However, the output of the filename_e.out file requires the presence of NLENRG Bulk/Subcase Entry pair.
- The global energy variables
include:
- • Total strain energy
- Plastic dissipation energy
- Hourglass energy
- Static stabilization energy
- Contact stabilization energy
- The element energy variables
include:
- Hourglass energy
- The contact/gap energy variables
include:
- Implicit nonlinear analysis does not support hourglass elements and so hourglass energy is always zero.
- Energy output for implicit nonlinear analysis is only controlled by the NLENRG Bulk/Subcase Entry pair. There is no influence of NLMON or NLOUT entries on the nonlinear energy output. Additionally, energy is always output on-the-fly dynamically during the analysis.
- For Explicit Dynamic Analysis, currently only the FREQ option is supported.
