RFORCE
Bulk Data Entry Defines a static loading condition due to a centrifugal force field. It can also be used to define the EXCITEID field (Amplitude "A") of dynamic loads in RLOAD1, RLOAD2 , TLOAD1 and TLOAD2 Bulk Data Entries.
RFORCE | SID | G | CID | A | R1 | R2 | R3 | ||
RACC | MB | IDRF |
RFORCE | 2 | 5 | 0.0 | 0.0 | 1.0 | 2.2 | |||
1.0 |
SID | Load set identification
number. No default (Integer > 0) |
G | Grid point identification
number through which the rotation vector acts.
Default = 0 (Integer ≥ 0) |
CID | Coordinate system defining
the components of the rotation vector.
Default = 0 (Integer ≥ 0 or <String>) |
A | Scale factor of the
rotational velocity in revolutions per unit time. Default = 0.0 (Real) |
R1,R2,R3 | Rectangular components of
rotation direction vector. The vector defined will pass through
point G. No default (Real; R12 + R22 + R32 > 0.0) |
RACC | Scale factor of the
rotational acceleration in revolutions per unit time squared. The
continuation line containing RACC is
optional. (Real) |
MB | Specifies the Bulk Data
section in which CID is defined. This entry is
applicable only for partitioned superelements. 7
(Integer ≥ -1) |
IDRF | Set identification number of an element set (SET Bulk Data Entry) to which this RFORCE entry applies. This field can be used to define different rotational forces to different parts of the model. |
- The rotational forces that are created with an
RFORCE entry for a constant angular velocity
), act in the positive radial
direction. They represent the initial forces on the structure due to a constant
angular velocity. The rotational forces defined for a constant angular
acceleration (RACC), act in the same direction as the angular
acceleration. They would be opposite to the inertia forces on the structure due
to a constant angular acceleration. The following plot shows that the
RFORCE vector at node Gi is given
by:
(1) Where,- angular velocity
- angular acceleration
Figure 1. RFORCE Vector at Node Gi - The RFORCE load is selected for use in a subcase by the Subcase Information Entry LOAD.
- The load vector generated by this entry can be printed using the I/O Option OLOAD.
- For CONM1 and
CONM2 entries, OptiStruct
calculates the torque, due to rotation, as:
(2) Where, is the moment of inertia.
- For mass penalization information when RFORCE is used in a Topology optimization, see Design Variables for Topology Optimization in the User Guide.
- String based labels allow for easier visual identification, including when being referenced by other entries. For more details, refer to String Label Based Input File.
- In the context of partitioned superelements, the coordinate systems in the main Bulk Data section are defined with respect to the assembly basic coordinate system, which is fixed. This feature is useful when loading needs to be defined in a fixed coordinate system, irrespective of the orientation of the superelement, defined by a partitioned Bulk Data section.
- This card is represented as a load collector in HyperMesh.
