MATX43
Bulk Data Entry Defines additional material properties for Hill Orthotropic material for geometric nonlinear analysis. This law is only applicable to two-dimensional elements.
| MATX43 | MID | R00 | R45 | R90 | CHARD | EPSPF | EPST1 | EPST2 |
| TID1 | FSCA1 | EPSR1 | |||||||
| TID2 | FSCA2 | EPSR2 | |||||||
| etc | etc | etc |
| MAT8 | 102 | 0.7173 | 0.7173 | 0.3 | 0.4 | 2.7 | |||
| MATX43 | 102 | 1.0 | 1.0 | 2.0 | |||||
| 1 | 1.0 | 0.1 | |||||||
| 2 | 1.0 | 0.05 |
| MID | Material ID of the
associated MAT8. 1 No default (Integer > 0) |
| R00 | Lankford parameter at
0 degree. Default = 1.0 (Real) |
| R45 | Lankford parameter at
45 degrees. Default = 1.0 (Real) |
| R90 | Lankford parameter at
90 degrees. Default = 1.0 (Real) |
| CHARD | Hardening
coefficient.
(1.0 ≥ Real ≥ 0.0) |
| EPSPF | Failure plastic
strain. Default = 1030 (Real) |
| EPST1 | Tensile failure
| EPST2 | Tensile failure
strain. Default = 2.0*1030 (Real) |
| TIDi | Identification number
of a TABLES1 that defines the yield stress
versus plastic strain function corresponding to
EPSRi. Separate functions must be defined
for different strain rates. Integer > 0 |
| FSCAi | Scale factor for
ith function. Default= 1.0 (Real) |
| EPSRi | Strain rate for
ith function. (Real) |
- The material identification number must be that of an existing MAT8 Bulk Data Entry. Only one MATX43 material extension can be associated with a particular MAT8. E1 must be equal to E2 on MAT8 that is extended by MATX43.
- MATX43 is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS = EXPDYN. It is ignored for all other subcases.
- The yield stress is defined by a user function and the yield stress is compared to equivalent stress.
- Angles for Lankford parameters are defined
with respect to orthotropic direction 1.
(1) - The Lankford parameters rα are determined from a simple tensile test at an angle α to the orthotropic direction 1.
- If the last point of the first (static) function equals 0 in stress, default value of failure plastic strain EPSPF is set to the corresponding value of plastic strain, p.
- If plastic strain p reaches failure plastic strain pmax, the element is deleted.
- If
1 (largest principal strain) >
t1(EPST1), stress is
reduced according to the following relation:
- If
t2(EPST2),
the stress is reduced to be 0 (but the element is not deleted). If
(EPSRn), yield is
interpolated between ƒn and
ƒn-1. If
(EPSR1), function ƒ1 is used.
Above
, yield is extrapolated.
Figure 1. - This card is represented as extension to a MAT8 material in HyperMesh.
