PCNTX20
Bulk Data Entry Defines properties TYPE20 of a CONTACT interface for geometric nonlinear analysis.
| PCNTX20 | PID | ISYM | IEDGE | GRNDID | EdgeAngle | ||||
| IGAP | IBAG | IDEL | |||||||
| FPENMAX | |||||||||
| STFAC | FRIC | GAP | TSTART | TEND | |||||
| IBC | INACTI | VISS | VISF | ||||||
| IFRIC | IFILTR | FFAC | IFORM | ||||||
| FRICDAT | C1 | C2 | C3 | C4 | C5 | C6 |
| PCONT | 34 | ||||||||
| PCNTX20 | 34 |
| PID | Property identification
number of the associated PCONT. No default (Integer > 0) |
| ISYM | Symmetric contact flag.
If SSID defines a grid set, the contact is always a main-secondary contact. Default as defined by CONTPRM (Character) |
| IEDGE | Flag for edge generation
from secondary and main surfaces.
Default as defined by (Character) |
| GRNDID | Optional nodes group
identifier. (Integer) |
| EdgeAngle | Edges angle (used only if
IEDGE = FEAT) Default = 91 (Real) If angle between two edges is smaller than EdgeAngle, the edge is considered. |
| IGAP | Gap definition flag.
| IBAG | Airbag vent holes closure
flag in case of contact.
(Integer) |
| IDEL | Flag for node and segment deletion.
Default as defined by (Integer) |
| FPENMAX | Maximum initial
penetration factor (0 < FPENMAX < 1) 8 Default = 1.0 (Real) |
| STFAC | Interface stiffness scale
factor. Default as defined by (Real ≥ 0) |
| FRIC | Coulomb
friction. Default as defined by (Real ≥ 0) |
| GAP | Gap for impact activation.
4
6 Default as defined by (Real ≥ 0) |
| TSTART | Start time. Default = 0.0 (Real ≥ 0) |
| TEND | Time for temporary
deactivation. Default = 1030 (Real ≥ 0) |
| IBC | Flag for deactivation of
boundary conditions at impact applied to the secondary grid
set. Default as defined by (Character = X, Y, Z, XY, XZ, YZ, or XYZ) |
| INACTI | Handling of initial
penetrations flag. 9
Default as defined by (Integer = 0, 1, 2, 3, or 5) Valid in explicit analysis: 0, 1, 2, 3 and 5. Invalid entries are ignored. |
| VISS | Critical damping
coefficient on interface stiffness. Default as defined by (Real ≥ 0) |
| VISF | Critical damping
coefficient on interface friction. Default as defined by (Real ≥ 0) |
| IFRIC | Friction formulation flag.
10
| IFILTR | Friction filtering flag.
11
| FFAC | Friction filtering
factor. Default as defined by (Real = 0.0 ≤ FFAC < 1.0) |
| IFORM | Friction penalty
formulation type. 12
| FRICDAT | Indicates that additional information for will follow. Only available when = GEN, DARM or REN. | |
| C1, C2, C3, C4, C5, C6 | Coefficients to define
variable friction coefficient in = GEN,
DARM, or REN. Default as defined by (Real ≥ 0) |
- The property identification number must be that of an existing PCONT Bulk Data Entry. Only one PCNTX20 property extension can be associated with a particular PCONT.
- PCNTX20 is only applied in geometric nonlinear explicit dynamic analysis subcase which is defined by ANALYSIS = EXPDYN. It is ignored for all other subcases.
- If FRIC is not explicitly defined on the PCONTX/PCNTX# entries, the MU1 value on the CONTACT or PCONT entry is used for FRIC in the /INTER entries for Geometric Nonlinear Analysis. Otherwise, FRIC on PCONTX/PCNTX# overwrites the MU1 value on CONTACT/PCONT.
- In implicit analysis, different contact
formulations are used for contact where secondary and main set do not overlap
and where they overlap (self-contact).
In the case of self-contact, the gap cannot be zero and a constant gap is used. For small initial gaps, the convergence will be more stable and faster if GAP is larger than the initial gap.
In implicit analysis, sometimes a stiffness with scaling factor reduction (for example, STFAC = 0.01) or reduction in impacted thickness (if rigid one) might reduce unbalanced forces and improve convergence, particularly in shell structures under bending where the effective stiffness is much lower than membrane stiffness; but it should be noted that too low of a value could also lead to divergence.
- If ISTF ≠ 1, the interface stiffness K is computed from the main segment stiffness Km
and/or the secondary segment stiffness Ks.
The main stiffness is computed from Km = STFAC * B * S * S/V for solids, Km = 0.5 * STFAC * E * t for shells.
The secondary stiffness is an equivalent nodal stiffness computed as Ks = STFAC * B * V-3 for solids, Ks = 0.5 * STFAC * E * t for shells.
In these equations, B is the Bulk Modulus, S is the segment area, and V is the volume of a solid. There is no limitation to the value of stiffness factor (but a value larger than 1.0 can reduce the initial time step).
The interface stiffness is K = max (STMIN, min (STMAX, K1)) with:- ISTF = 0, K1 = Km
- ISTF = 2, K1 = 0.5 * (Km + Ks)
- ISTF = 3, K1 = max (Km, Ks)
- ISTF = 4, K1 = min (Km, Ks)
- ISTF = 5, K1 = Km * Ks / (Km + Ks)
- The default for the constant gap (IGAP = CONST) is the minimum of:
- t, average thickness of the main shell elements
- l/10, l - average side length of the main solid elements
- lmin/2, lmin - smallest side length of all main segments (shell or solid)
- The variable gap (IGAP = VAR) is computed as: gs + gmwith:
- gm - main element gap with
gm = t/2, t: thickness of the main element for shell elements.
gm = 0 for solid elements.
- gs - secondary node gap:
gs = 0 if the secondary node is not connected to any element or is only connected to solid or spring elements.
gs = t/2, t - largest thickness of the shell elements connected to the secondary node.
gs = 1/2√S for truss and beam elements, with S being the cross section of the element.
If the secondary node is connected to multiple shells and/or beams or trusses, the largest computed secondary gap is used.
- Maximum penetration value is set as a
fraction of the actual gap (including variable gap):
Penmax = FPENMAX * gap
If the initial penetration of a secondary node is greater than the calculated maximum value (Penmax), the node will be deactivated from the interface (node stiffness deactivation).
- INACTI = 3, is only recommended for small initial penetrations and
should be used with caution because:
- the coordinate change is irreversible
- it may create other initial penetrations if several surface layers are defined in the interfaces
- it may create initial energy if the node belongs to a spring
elementINACTI = 5 works as follows:
- IFRIC defines the friction model.
IFRIC = COUL - Coulomb friction with FT ≤ FRIC * FN.
For IFRIC > 0, the friction coefficient is set by a function ( )
Where, is the pressure of the normal force on the main segment and is the tangential velocity of the secondary node.
The following formulations are available:- IFRIC = 1 - Generalized viscous friction
law
(1) - IFRIC = 2 - Darmstad law
(2) - IFRIC = 3 - Renard law
0 ≤ V ≤ C5 C5 ≤ V ≤ C6 C6 ≤ V Where,(3) - The first critical velocity Vcr1 must not be 0 (C5 ≠ 0). It also must be lower than the second critical velocity Vcr2 (C5 < C6).
- The static friction coefficient C1 and the dynamic friction coefficient C2, must be lower than the maximum friction C3 (C1 < C3 and C2 < C3).
- The minimum friction coefficient C4, must be lower than the static friction coefficient C1 and the dynamic friction coefficient C2 (C4 ≤ C1 and C4 ≤ C2).
law
- IFILTR defines the method for computing the friction filtering coefficient. If IFILTR ≠ NO, the tangential friction forces are smoothed using a
filter:
FT = α * F'T + (1 conref="../../bank/solvers_symbols_equations_r_b.dita#reference_xh2_vkk_pw/o2_sym_alpha" id="pcntx20_bulk_r_ph_z5p_lkn_l1b"/>) * F'T-1
Where,- FT
- Tangential force
- F'T
- Tangential force at time t
- F'T-1
- Tangential force at time t-1
- α
- Filtering coefficient
IFILTR = SIMP conref="../../bank/solvers_symbols_equations_r_b.dita#reference_xh2_vkk_pw/o2_sym_alpha" id="pcntx20_bulk_r_ph_jwp_jkn_l1b"/> = FFAC
IFILTR = PER conref="../../bank/solvers_symbols_equations_r_b.dita#reference_xh2_vkk_pw/o2_sym_alpha" id="pcntx20_bulk_r_ph_ubz_jkn_l1b"/> = 2π dt/FFAC, where dt/T = FFAC, T is the filtering period
IFILTR = CUTF conref="../../bank/solvers_symbols_equations_r_b.dita#reference_xh2_vkk_pw/o2_sym_alpha" id="pcntx20_bulk_r_ph_jyd_kkn_l1b"/> = 2π * FFAC * dt, where FFAC is the cutting frequency
- IFORM selects two types of contact friction penalty formulation.
The viscous (total) formulation (IFORM = VISC) computes an adhesive force as:
Fadh = VISF * √(2KM) * VT
FT = min ( FN, Fadh)
The stiffness (incremental) formulation (IFORM = STIFF) computes an adhesive force as:
Fadh = FTold + ΔFT
ΔFT = K * VT * dt
FTnew = min ( FN, Fadh)
- This card is represented as an extension to a PCONT property in HyperMesh.
