Bulk Data Entry Defines the parameters for explicit dynamic analysis.
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| RADPRM |
PARAM1 |
VALUE1 |
PARAM2 |
VALUE2 |
PARAM3 |
VALUE3 |
PARAM4 |
VALUE4 |
PARAM5 |
VALUE5 |
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| RADPRM |
HMNAME |
YES |
RBE2RBD |
YES |
| Field |
Contents |
SI Unit Example |
| PARAMi |
Name of parameter. 2 |
| VALi |
Value of
parameter. |
- The parameters defined by
RADPRM bulk card are only applied in explicit dynamic
analysis subcases which are defined by ANALYSIS = EXPDYN. It is
ignored for all other subcases.
- The parameters PARAM, NLAFILE, PARAM, NLRFILE, PARAM, NLRUN, and PARAM, SNAPTHRU can also be defined by PARAM Bulk card (for these parameters,
the PARAM card is now deprecated). However, if any of these
parameters is defined by both PARAM and RADPRM
cards at the same time, PARAM definition is ignored and
RADPRM is used.
