NLOAD1
Bulk Data Entry Defines a time-dependent load or enforced motion for use in explicit dynamic analysis.
| NLOAD1 | SID | EXCITEID | SENSID | TYPE | TID | B | C | CID | |
| TSTART | TEND |
| NLOAD1 | 5 | 7 | LOAD | 13 |
| SID | Load set identification
number. (Integer > 0) |
| EXCITEID | SID number of
DAREA, SPCD, GRAV or static
load set data entry that defines A. 2
3
5 (Integer > 0) |
| SENSID | Sensor identification number. Load
application is activated once the referenced sensor is activated. (Integer > 0) |
| TYPE | Defines the dynamic excitation type.
2
3 Default = 0 (Integer, character or blank) |
| TID | TABLEDi entry
identification number defining the load history F(t). (Integer > 0) |
| B | Scale factor of the time in
f(t). Default = 1.0 (Real > 0) |
| C | Scale factor for the function value in
f(t). Default = 1.0 (Real) |
| CID | Coordinate system identification number
defining a frame in which the imposed velocity is defined. Applies only for
TYPE = 2, V,
VE, VEL, or VELO. Only
CORD1R and CORD2R systems are
allowed. (Integer > 0 or blank) |
| TSTART | Start time. 4 Default = 0.0 (Real ≥ 0.0) |
| TEND | End time. Default = 1030 (Real > TSTART) |
- Time-dependent load sets must be selected with the Subcase Information command NLOAD = SID. It can only be selected in Explicit Dynamic Analysis subcases which are defined by an ANALYSIS = EXPDYN Subcase Informaton Entry.
- The type of the dynamic excitation is specified
by TYPE according to:
- TYPE
- TYPE of Dynamic Excitation
- 0, L, LO, LOA, or LOAD
- Applied load (force, moment, pressure, GRAV).
- 1, D, DI, DIS, or DISP
- Enforced displacement using SPC/SPCD data.
- 2, V, VE, VEL, or VELO
- Enforced velocity using SPC/SPCD data.
- 3, A, AC, ACC, or ACCE
- Enforced acceleration using SPC/SPCD data.
- The TYPE also
determines the manner in which EXCITEID is used by the program as:
- Excitation specified by TYPE is applied load. The EXCITEID may reference DAREA, or (and) static load set entries. If EXCITEID references both DAREA and static load set, the two loads will be super-imposed.
- Excitation specified by TYPE is enforced motion. The EXCITEID must reference SPCD entries.
- TSTART and TEND are only considered for enforced displacement, velocity, and acceleration. The continuation line is optional.
- If a GRAV Bulk Data Entry is referenced in the EXCITEID field, the TYPE field should be set to LOAD.
- This card is represented as a load collector in HyperMesh.
