Bulk Data Entry Defines coefficients of a power series for use in generating
temperature-dependent material properties. Also contains parametric data for use with the
table.
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| TABLEM4 |
TID |
X1 |
X2 |
X3 |
X4 |
A0 |
A1 |
A2 |
A3 |
A4 |
A5 |
etc. |
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| TABLEM4 |
28 |
0.0 |
1.0 |
0.0 |
100 |
2.91 |
-0.0329 |
6.51-5 |
0.0 |
-3.4-7 |
ENDT |
| Field |
Contents |
SI Unit Example |
| TID |
Table identification number. (Integer
> 0)
| Xi |
Table parameters. (Real; X2 ≠ 0.0; X3
< X4)
| Ai |
Coefficients. (Real)
- At
least one continuation entry must be
specified.
- The
end of the table is indicated by the existence of
ENDT in the field following the
last entry. An error is detected if any
continuations follow the entry containing the
end-of-table flag ENDT.
- TABLEM4 uses the algorithm:(1)
Where,
- Input to the table
- Is returned
- Is supplied from the MATi entry
Whenever
, use X3 for
; whenever
, use X4 for
. There are N + 1 entries in the table. There are no error
returns from this table look-up procedure.
- This
card is represented as a load collector in
HyperMesh.
