Bulk Data Entry Defines units for multibody, component mode
synthesis (flexible-body preparation), and Explicit Dynamic Analysis (EXPDYN)
sequences.
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| DTI |
UNITS |
1 |
MASS |
FORCE |
LENGTH |
TIME |
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| DTI |
UNITS |
1 |
KG |
N |
M |
S |
| Field |
Contents |
SI Unit Example |
| MASS |
Units of mass. 3
- kg (Default)
- kilogram
- lbm
- pound-mass
- slug
- slug
- gram
- gram
- ozm
- ounce-mass
- klbm
- kilo pound-mass (1000.lbm)
- mgg
- megagram
- slinch
- 12 slugs
- ug
- Microgram
- ng
- Nanogram
- uston
- US ton
- mg
- Milligram
| FORCE |
Units of force. 3
- n (Default)
- newton
- lbf
- pounds-force
- kgf
- kilograms-force
- ozf
- ounce-force
- dyne
- dyne
- kn
- kilonewton
- klbf
- kilo pound-force (1000.lbf)
- mn
- Millinewton
- un
- Micronewton
- nn
- Nanonewton
| LENGTH |
Units of length. 3
- mm (Default)
- millimeter
- km
- kilometer
- m
- meter
- cm
- centimeter
- mi
- mile
- ft
- foot
- in
- inch
- um
- Micrometer
- nm
- Nanometer
- ang
- Angstrom
- yd
- yard
- mil
- Milli-inch
- uin
- Micro-inch
| TIME |
Units of time. 3
- s (Default)
- seconds
- h
- hours
- min
- minutes
- ms
- milliseconds
- us
- Microsecond
- nanosec
- Nanosecond
- d
- day
- PARAM, WTMASS is ignored for the
multibody and component mode synthesis (flexible-body preparation) solution
sequences. Unit data for these solution sequences is supplied on the
DTI,UNITS Bulk Data Entry.
- This DTI,
UNITS Data Entry is the same as the UNITS entry.
- If the units defined on the
DTI,UNITS entry are not consistent,
mass unit is ignored, only force, length, and time units are considered in
Explicit Dynamic Analysis (EXPDYN) subcases.
- This card is represented as a control
card in HyperMesh.
