Bulk Data Entry Used to list the grids that lie on the axis of symmetry, in cyclic symmetry
analysis.
Format 1
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| CYAX |
GID1 |
GID2 |
GID3 |
GID4 |
GID5 |
GID6 |
GID7 |
GID8 |
GID9 |
GID10 |
etc. |
Format 2
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| CYAX |
GID1 |
GID2 |
GID3 |
THRU |
GID5 |
GID6 |
GID7 |
GID8 |
GID9 |
GID10 |
etc. |
Example 1
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| CYAX |
101 |
27 |
50 |
51 |
52 |
53 |
54 |
55 |
122 |
Example 2
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| CYAX |
102 |
27 |
50 |
THRU |
55 |
122 |
| Field |
Contents |
SI Unit Example |
| GIDi |
Unique grid point identification number. No default
(Integer > 0)
- Grid points on the axis of symmetry
should not be defined on the CYJOIN entry.
- The displacement coordinate system
(CD field on the GRID
entry) for a grid on CYAX must be rectangular. The Z-axis
in this coordinate system must coincide with the axis of symmetry for the
model.
- Grid points on
CYAX may be constrained by SPCs, but not by MPCs. If
all components are constrained by SPC, the grid point will be internally
ignored from the CYAX list.
- When 3 or more cyclic symmetric
segments (defined by NSEG field on the CYSYM entry) are involved, then any SPC to be
applied to the grids on CYAX should satisfy the following
rule:
- Both components 1 and 2 should be constrained, otherwise neither of
them should be constrained. The same rule applies to components 4
and 5.
- There is no restriction to components 3 and 6.
- By default, the axis of symmetry is
defined by the first grid pair on the CYJOIN entry, while
the CYAX entry does not define the axis of symmetry for
cyclic symmetry analysis. Adding PARAM, AXCYSYM, YES allows the axis of symmetry to be defined
according to the grids listed on the CYAX entry, instead
of using the grids from the CYJOIN entry, and the rules
described in 2 still apply.
