TEMPT
Bulk Data Entry Defines parameters for mapping the grid temperature field from either an external file or an internal heat transfer subcase to Nonlinear Static Analysis. The mapping is over time-domain only.
| TEMPT | ID | HST | HSI | ||||||
| PARAM1 | VALUE1 | PARAM2 | VALUE2 |
| TEMPT | 23 | HFILE | 202 | ||||||
| HTINI | 0.5 | HTFIN | 4.0 |
| ID | Unique identification
number. 2 No default (Integer > 0) |
| HST | Heat source type.
No default |
| HSI | Heat source
identification number. For HFILE, this field provides the identification number of the external file (ID defined on ASSIGN,HFILE). For HSUB, this field provides the identification number of the internal transient heat transfer subcase. No default (Integer > 0) |
| The various PARAMi definitions are listed below, along with their corresponding allowed VALUEi ranges and default values. | ||
| HTINI | The initial time in
HFILE/HSUB, at which the
grid temperature field is used for nonlinear static analysis at
subcase time = 0.0. If HTINI is not defined,
the earliest time defined in the referenced
HFILE/HSUB will be used.
The time defined in HFILE/HSUB
is global time. Default = blank (Real) |
| HTFIN | The final time in
subcase time = TTERM (defined in
NLPARM card). If HTFIN
is not defined, the last time defined in the referenced
- The TEMPT Bulk Data Entry is selected by the Subcase Information Entry TEMP(LOAD,TEMPT)=ID.
- TEMPT entry identification number should be unique with respect to the TEMP entry.
- The temperature field defined in
HFILE/HSUB is a mapping from the time
domain in between HTINI and HTFIN to
nonlinear static analysis time domain linearly.
Figure 1. - In case that TEMP(INIT) is not defined in the deck file, the temperature field corresponding to HTINI is used as initial temperature field.
