MOTNJG
Bulk Data Entry Defines motion for joint connector JOINTG Bulk Data Entry.
| MOTNJG | ID | ||||||||
| JID1 | DOF | VALUE | |||||||
| JID2 | DOF | VALUE | |||||||
| etc. |
| MOTNJG | 3 | ||||||||
| 2 | 1 | 1.0 | |||||||
| 3 | 2 | 2.0 |
| ID | Motion set identification
number. (Integer > 0) |
| JIDi | Identification number of a JOINTG Bulk Data Entry on which the motion is to be applied. | |
| DOF | Degree of freedom
component number. No default (1 ≤ Integer ≤ 6) |
| VALUE |
No default |
- The MOTNJG Bulk Data Entry can be referenced in the corresponding MOTNJG Subcase Information Entry.
- If a MOTNJG Bulk Data Entry is not referenced in any subcase, then it is not used in the solution.
