GRID
Bulk Data Entry Defines the location of a geometric grid point of the structural model, the directions of its displacement, and its permanent single-point constraints.
| GRID | ID | CP | X1 | X2 | X3 | CD | PS |
| GRID | 2 | 3 | 1.0 | -2.0 | 3.0 | 316 |
| ID | Unique grid point identification
number. (Integer > 0) |
| CP | Coordinate system identification number
in which the location of the grid point is defined. (Integer ≥ 0 or blank) |
| X1, X2, X3 | Location of the grid point in coordinate
system CP. (Real) |
| CD | Coordinate system identification number
in which the displacements, degrees-of-freedom, constraints, and solution vectors
are defined at grid point.
(Integer ≥ -1 or blank) |
| PS | Permanent single-point constraints
associated with grid point. Up to six unique digits may be placed in the field with
no imbedded blanks. (Integer ≥ 0 or blank) |
See the GRDSET entry for default options for fields 3, 7, and 8.
- All grid point identification numbers must be unique with respect to all other structural grid and scalar points. A duplicate identification number is only allowed if all fields on the duplicated entries are exactly the same, unless PARAM,DUPTOL is used. PARAM,DUPTOL can be used to set a tolerance that will allow a GRID with same ID, CP, CD, and PS to have slightly different coordinates.
- The meaning of X1, X2, and
X3 depends on the type of coordinate system, CP,
as follows: (see CORDI entry
descriptions).
Type X1 X2 X3 Rectangular X Y Z Cylindrical R q(degrees) Z Spherical R q(degrees) f(degrees) - The collection of all CD coordinate systems defined on all GRID entries is called the Global Coordinate System. All degrees-of-freedom, constraints, and solution vectors are expressed in the Global Coordinate System.
- If CP, PS, or CD is blank, information from the GRDSET data will be used. If CP or CD contains a zero, the basic coordinate system will be used. If PS contains a zero, single point constraints on the GRDSET data are ignored.
- Input data replication is available for the GRID data. This can be used to generate additional GRID data, based on incrementing the GRID ID and coordinate locations.
- This card is represented as a node in HyperMesh.
