MATX25
Bulk Data Entry Defines an elasto-plastic orthotropic material with Tsai-Wu and CRASURVT yield criteria for composite shell materials.
| MATX25 | MID | EPSF1 | EPSF2 | EPST1 | EPSM1 | EPST2 | EPSM2 | DTENDS | |
| WPMAX | WPREF | IOFF | GAMINI | GAMMAX | DMAX | RATIO | |||
| FSMOOTH | FCUT | IFORM |
| B | N | FMAX | |||||||
| SY1T | SY2T | SY1C | SY2C | ALFA | |||||
| SY12C | SY12T | C12 | EPSR0 | ICC |
| C | EPSR0 | ALFA | ICCG | ||||||
| SY1T | B1T | N1T | SMAX1T | C1T | |||||
| EPS1T1 | EPS2T1 | SRST1 | WMPT1 | ||||||
| SY2T | B2T | N2T | SMAX2T | C2T | |||||
| EPS1T2 | EPS2T2 | SRST2 | WMPT2 | ||||||
| SY1C | B1C | N1C | SMAX1C | C1C | |||||
| EPS1C1 | EPS2C1 | SRSC1 | WMPC1 | ||||||
| SY2C | B2C | N2C | SMAX2C | C2C | |||||
| EPS1C2 | EPS2C2 | SRSC2 | WMPC2 | ||||||
| SY12T | B12T | N12T | SMAX12T | C12T | |||||
| EPS1T12 | EPS2T12 | SRST12 | WMPT12 |
| MAT8 | 102 | 70000 | 70000 | 0.3 | 26923.1 | 26923.1 | 26923.1 | ||
| MATX25 | 102 | 0.15 | 0.2 | 0.95 | |||||
| 2 | |||||||||
| 0.2 | 1.0 | 2.0 | |||||||
| 1E10 | 1E10 | 1E10 | 1E10 | ||||||
| 1E10 | 1E10 |
| MID | Material ID of the associated MAT8. 1 No default (Integer > 0) |
| EPSF1 | Total tensile failure in direction
1. Default = 1E30 (Real) |
| EPSF2 | Total tensile failure in direction
2. Default = 1E30 (Real) |
| EPST1 | Tensile failure strain in direction
1. (Real) |
| EPSM1 | Maximum strain in direction
1. (Real) |
| EPST2 | Tensile failure strain in direction
2. (Real) |
| EPSM2 | Maximum strain in direction
2. (Real) |
| DTENDS | Maximum damage of composite tensile
strength. Default = 0.999 (Real < 1.0) |
| WPMAX | Maximum plastic work. Default = 1E30 (Real) |
| WPREF | Reference plastic work. Default = 1.0 (Real) |
| IOFF | Total element failure criteria.
Default = 0 (Integer) |
| GAMINI | Delamination shear strain. 11 Default = 1E30 (Real) |
| GAMMAX | Maximum shear strain. Default = 1.1E30 (Real) |
| DMAX | Maximum damage. Default = 1.0 (Real) |
| RATIO | Ratio parameter control to delete shell
elements.
| FSMOOTH | Strain rate smoothing flag.
| FCUT | Cutoff frequency for strain rate
filtering. Default = 1E30 (Real) |
| IFORM | Formulation flag.
| IFORM=TSAI | ||
| B | Hardening
parameter. (Real) |
| N | Hardening exponent. Default = 1.0 (Real) |
| FMAX | Maximum value of yield
function. Default = 1E30 (Real) |
| SY1T | Tension in direction 1. (Real > 0) |
| SY2T | Tension in direction 2. (Real > 0) |
| SY1C | Compression yield stress in direction
1. (Real > 0) |
| SY2C | Compression yield stress in direction
2. (Real > 0) |
| ALFA | F12 reduction factor. Default = 1.0 (Real) |
| SY12C | Compression yield stress in direction
12. (Real > 0) |
| SY12T | Tension yield stress in direction
12. (Real > 0) |
| C12 | Strain rate coefficient.
(Real) |
| EPSR0 | Reference strain
rate. (Real) |
| ICC | Yield stress in shear and strain rate
flag. 9
(Integer) |
| IFORM=CRAS | ||
| C | Global strain rate coefficient for
plastic work criteria. (Real) |
rate. (Real) |
| ALFA | F12 reduction factor. Default= 1.0 (Real) |
| ICCG | Global composite plasticity parameters
flag for strain rate computation: 9
(Integer) |
| SY1T | Tension yield stress in direction
1. (Real > 0) |
| B1T | Hardening parameter in direction
1. (Real) |
| N1T | Hardening exponent in direction
1. Default = 1.0 (Real) |
| SMAX1T | Maximum stress in direction 1. Default = 1E30 (Real) |
| C1T | Strain rate coefficient in direction
1.
Default = C (Real) |
| EPS1T1 | Initial softening strain in direction
| EPS2T1 | Maximum softening strain in direction
1. Default = 1.2 * EPS1T1 (Real) |
| SRST1 | Residual stress in direction
1. Default = 10E-3*SY1T (Real) |
| WMPT1 | Maximum plastic work in tension
| SY2T | Tension yield stress in direction
2. (Real > 0) |
| B2T | Hardening parameter in direction
2. Default = B1T (Real) |
| N2T | Hardening exponent in direction
2. Default = N1T (Real) |
| SMAX2T | Maximum stress in direction 2. Default = 1E30 (Real) |
| C2T | Strain rate coefficient in direction
2.
| EPS1T2 | Initial softening strain in direction
| EPS2T2 | Maximum softening strain in direction
2. Default = 1.2*EPS1T1 (Real) |
| SRST2 | Residual stress in direction
2. Default = 10E-3 * SY2T (Real) |
| WMPT2 | Maximum plastic work in tension
1. (Real > 0) |
| B1C | Hardening parameter in direction
1. Default = B2T (Real) |
| N1C | Hardening exponent in direction
1. Default = N2T (Real) |
| SMAX1C | Maximum stress in direction 1. Default = 1E30 (Real) |
| C1C | Strain rate coefficient in direction
1.
| EPS1C1 | Initial softening strain in direction
| ESP2C1 | Maximum softening strain in direction
1. Default = 1.2*EPS1C1 (Real) |
| SRSC1 | Residual stress in direction
1. Default = 10E-3*S1YC (Real) |
| WMPC1 | Maximum plastic work in compression
2. (Real > 0) |
| B2C | Hardening parameter in direction
2. Default = B1C (Real) |
| N2C | Hardening exponent in direction
2 Default = N1C (Real) |
| SMAX2C | Maximum stress in direction 2. Default = 1E30 (Real) |
| C2C | Strain rate coefficient in direction
2.
| EPS1C2 | Initial softening strain in direction
| EPS2C2 | Maximum softening strain in direction
2. Default = 1.2*EPS1C2 (Real) |
| SRSC2 | Residual stress in direction
2. Default = 10E-3*S2YC (Real) |
| WMPC2 | Maximum plastic work in compression
12. (Real > 0) |
| B12T | Hardening parameter in direction
12. Default = B2C (Real) |
| N12T | Hardening exponent in direction
12. Default = 1.0 (Real) |
| SMAX12T | Maximum stress in direction
12. Default = 1E30 (Real) |
| C12T | Strain rate coefficient in direction
12.
| EPS1T12 | Initial softening strain in direction
| EPS2T12 | Maximum softening strain in direction
12. Default = 1.2*EPS1T12 (Real) |
| SRST12 | Residual stress in direction
12. Default = 10E-3*SY12T (Real) |
| WMPT12 | Maximum plastic work in shear. Default = 1E30 (Real) |
- The material identification number must be that of an existing MAT8 Bulk Data Entry. Only one MATXi material extension can be associated with a particular MAT8.
- MATX25 is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS=EXPDYN. It is ignored for all other subcases.
- Tsai-Wu formula (IFORM=TSAI) is not available with QEPH (ISHELL=24 on PCOMPX) shell elements, it is only available with Q4 (ISHELL=1, 2, 3, 4 on PCOMPX) and QBAT(ISHELL=12 on PCOMPX) shell elements.
- The Lamina yield surface for Tsai-Wu criteria
(IFORM=TSAI) is:
(1) Where,- Wp
- Plastic work
- Reference plastic work
- Yield envelope evolution
Where,- b
- hardening parameter for plastic work
- n
- hardening exponent
- The CRASURV model is an improved version of the
former law based on the standard Tsai-Wu criteria. The main changes concern the expression
of the yield surface before plastification and during work hardening. First, in a CRASURV
model, the coefficient
depends only on one input parameter:
(2) Another modification concerns the parameters Fij which are expressed now in function of plastic work and plastic work rate:(3) (4) (5) (6) (7) - If the total tensile failure value EPSF1 is reached in the direction 1 and respectively EPSF2 in the direction 2, the stresses tensor in the layer is permanently reset to 0.
- If a shell has several layers with one material per layer (different materials, different IOFF), the IOFF used is the one that is associated to the shell in the shell element definition.
- Both Wp* and Wp*max are
defined as:
(8) - The plastic work criteria is:
(9) When ICC=2, 3, or 4 for Tsai-Wu formula, when ICCG=3 or 4 for CRASURV formula.
- Delamination is a global model:
(10) (11) with applies to the all shell and not independently per each layer. - Thereby, the coefficients GAMINI, GAMMAX, and DMAX considered, are the coefficients which are defined in the global material associated to the shell equivalent out-of-plane shear strain.
- The IOFF and RATIO field values are utilized only if they are defined in the material assigned to a part, these fields are not considered if they are only defined in material used for a layer in the property entry. This option is not available for solid elements.
- This card is represented as extension to a MAT8 material in HyperMesh.
