FATSDR
Bulk Data Entry Defines the solder joint for consideration in solder fatigue analysis.
| FATSDR | ID | SDRTYP | SIDPKG | SIDPCB | |||||
| DIM | PKGLEN | SDRTHK | |||||||
| SOLDER | SDR1 | SDR2 | etc | etc | etc |
| ID | Entry identification
number. Each FATSDR entry must have a unique ID. The FATDEF Subcase Information entry may reference this ID. No default (Integer > 0) |
| SDRTYP | Defines solder joint
type.
No default |
| SIDPKG | Element SET identification
number of the component. No default (Integer > 0) |
| SIDPCB | Element SET identification
number of the PCB. No default (Integer > 0) |
| DIM | Optional continuation line indicating the dimension information follows. | |
| PKGLEN | Component length.
| PKGTHK | Solder thickness.
| SOLDER | Continuation line indicating the solder SETs follow. | |
| SDRi | Element SET of solder
"i." No default (Integer > 0) |
- For SDRTYP=XLEAD, two SDRi are expected. Otherwise, an error is issued during the run.
- Fatigue load should be a static load with Thermal Expansion Coefficient defined.
- Load History via the TABFAT entry is not allowed.
- If DIM continuation line is not specified, OptiStruct will attempt to measure this from Finite Element Mesh data.
