Bulk Data Entry Used to assign property ID to elements in
DMIG.
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| EL2PROP |
ID |
ELSETID |
PTYPE |
PROPID |
ELSETID |
PTYPE |
PROPID |
ELSETID |
PTYPE |
PROPID |
ELSETID |
PTYPE |
PROPID |
etc |
Alternate Format
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| EL2PROP |
ID |
ALTER |
PROPID |
ELSETID |
ELSETID |
ELSETID |
ELSETID |
ELSETID |
ELSETID |
ELSETID |
ELSETID |
ELSETID |
ect |
ect |
PROPID |
ELSETID |
ELSETID |
ELSETID |
ELSETID |
ELSETID |
ELSETID |
ELSETID |
ELSETID |
ELSETID |
ect |
ect |
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| EL2PROP |
7 |
8 |
PSHELL |
3 |
Alternate Format Example
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| EL2PROP |
7 |
ALTER |
3 |
8 |
2 |
| Field |
Contents |
SI Unit Example |
| ID |
Identification number of
EL2PROP. No default (Integer >
0)
| ALTER |
ALTER
flag indicating the alternate format is being used. |
| ELSETID |
Element set identification
number. No default (Integer > 0)
| PTYPE |
(Optional) Property
type.
- PSHELL
- PSOLID
| PROPID |
Property identification
- This EL2PROP Bulk
Data Entry can be used to assign Property ID's' to Element sets.
- The ID field is only
used by HyperMesh. When ECHO entry is
present in the model, all EL2PROP entries will be combined into
one EL2PROP entry with an internally generated
ID. The ID of the
EL2PROP entries are not used in OptiStruct.
