LINE
Bulk Data Entry Definition of a line.
| LINE | LINEID | EDGE | |||||||
| GA1 | GB1 | ||||||||
| GA2 | GB2 | ||||||||
| GA3 | GB3 | ||||||||
| etc | etc |
| LINE | 100 | EDGE | |||||||
| 33 | 34 | ||||||||
| 34 | 35 | ||||||||
| 35 | 36 |
Alternate Format
| LINE | LINEID | ELEDGE | |||||||
| EID1 | EID2 | EID3 | EID4 | EID5 | EID6 | EID7 | EID8 | ||
| EID9 | etc |
Alternate Format (SET)
| LINE | LINEID | SET | SID |
| LINEID | Non-unique identification number of
LINE. Multiple LINE cards with the same
LINEID compose a line group. No default (Integer > 0) |
| EDGE | Flag indicating that a line is defined by two grids. | |
| GA# | Grid point identification number of
first grid A. No default (Integer > 0) |
| GB# | Grid point identification number of
second grid B. No default (Integer > 0) |
| ELEDGE | Flag indicating that the line is composed of elements. | |
| EID# | Element identification number. No default (Integer > 0) |
| SET | Flag indicating that the line is defined by a SET of elements. | |
| SID | Set identification number. No default (Integer > 0) |
- GA and GB should be two different grids.
- All nodes must belong to a shell, solid, truss or beam element.
- This card is represented as a contact surface in HyperMesh.
