Bulk Data Entry Defines rigid
material for geometric nonlinear analysis.
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| MATX13 |
MID |
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| MAT1 |
102 |
10.0 |
0.495 |
6.0E-10 |
| MATX13 |
102 |
| Field |
Contents |
SI Unit Example |
| MID |
Material ID of the associated
MAT1. 1 No default
(Integer > 0)
- The
material identification number must be that of an
existing MAT1 Bulk Data Entry. Only one
MATXi material extension can be
associated with a particular
MAT1.
- MATX13 is only applied
in geometric nonlinear analysis subcases which are
defined by ANALYSIS=EXPDYN. It is ignored for all
other subcases.
- This
card is represented as a material in HyperMesh.
