MATX42
Bulk Data Entry Defines additional material properties for Ogden, Mooney-Rivlin material for geometric nonlinear analysis. This material is used to model rubber, polymers, and elastomers.
| MATX42 | MID | SCUT | TBID | FBULK | |||||
| LAW | MU1 | ALFA1 | MU2 | ALFA2 | MU3 | ALFA3 | |||
| MU4 | ALFA4 | MU5 | ALFA5 |
| PRONY | G1 | T1 | G2 | T2 | G3 | T3 | |||
| G4 | T4 | G5 | T5 | etc |
| MAT1 | 102 | 10.0 | 0.495 | 6.0E-10 | |||||
| MATX42 | 102 | ||||||||
| LAW | 0.10 | 2.0 | -0.010 | -2.0 |
| MID | Material ID of the
associated MAT1. 1 No default (Integer > 0) |
| SCUT | Cut-off stress in
tension. Default = 1030 (Real ≥ 0) |
| TBID | Identification number
of a TABLES1 to define the bulk function f(J)
that scales the bulk modulus versus relative volume. If
TBID = 0, f(J) = const. = 1.0. Default = 0 (Integer ≥ 0) |
| FBULK | Scale factor for bulk
function. Default = 1.0 (Real > 0) |
| LAW | Indicates that material parameters MUi and ALFAi follow. | |
| MUi | Parameter
. Up to five pairs are
permitted. (Real) |
| ALFAi | Parameter
permitted. (Real) |
| PRONY | Indicates that prony model parameters Gi and Ti follow. | |
| Gi | Parameter
Gi for prony model.
8
9 (Real) |
| Ti | Parameter
Ti for prony model.
8
9 (Real) |
- The material identification number must be that of an existing MAT1 Bulk Data Entry. Only one MATXi material extension can be associated with a particular MAT1.
- MATX42 is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS = EXPDYN. It is ignored for all other subcases.
- The recommended Poisson's ratio for incompressible material is NU = 0.495. NU is defined on the corresponding MAT1.
- The strain energy density
is computed using:
(1) Where, is the ith principal engineering stretch ( , is the ith principal engineering strain). The Cauchy stress is computed as:
(2) with J = 1 * 2 * 3 being the relative volume:
(3) The quantity, P is the pressure:
P = K * FBULK * f (J) * (J - 1)
The Bulk Modulus, is:(4) with the ground shear modulus :
- An incompressible Mooney-Rivlin material
is governed by:
W = C10 (I1 - 3) + C01 (I2 - 3)
Where, Ii is ith invariant of the right-hand Cauchy-Green Tensor. It can be modeled using the following parameters:
1 = 2 * C10
2 = -2 * C01
α1 = 2.0
α2 = -2.0
- Coefficients of the Prony series
(Gi,
Ti) are used to
describe viscous effects using the Maxwell model (which can be described in a
simplified manner as a system of n springs with stiffness'
Gi and dampers
i):
Figure 1.The hyperelastic ground shear modulus, is exactly the long-term shear modulus G∞ in the Maxwell model, and Ti is the relaxation time:(5) The Gi and Ti values must be positive.
- Viscous effects are modeled through a
convolution integral using Prony series. This is an extension of small strain
theory (described in comment 6) to large nonlinear strain case. The Kirchhoff
viscous stress is given by:
(6) with, F being the deformation gradient matrix, and denotes the deviatoric part of tensor .
The viscous-Cauchy stress is written as:(7) - This card is represented as a material in HyperMesh.
